CFS-Air in tubes
CFS-Air in tubes
2003-06-24 by jimenez12fr
Hello,
I've just installed a CFS system from MIS on an Epson 1290 printer
with VM quadtones. I had problems with the vacuum filling method (I
managed somehow to break to vacuum pump provided by MIS) and in the
end I used the bottom filling method to fill the cartridges. I
inserted a syringue at the bottom, breaking the seal, connected the
tubes to the ink bottles and started pulling the syringue until I
got some ink in it. It worked fine, and it prints well, but shortly
afterwards I saw that the tubes are filled with air in long parts of
it close to the cartridge. The section of the tubes next to the
bottles have ink in them. I've made only 4-5 prints so far.
Question: Is the air going to damage the system? I fear that the
printer is using the ink in the cartridges, but once it starts
getting air inside everything will be messed up. Anyone had this
problem before? Should I refill the cartridge, and how could I do
it? Pulling all the ink and air with a syringue until I have a lot
of ink in it?
Sorry for this naif question in the middle of so high tech
discussions here. Like many, I follow them with interest trying to
understand what's going on. Thanks in advance.
