IJC & EyeOne Spectrophotometer
2003-07-08 by klog52756
I am wondering if the EyeOne spectrophotometer (bundled with the Eye
One Photo) would be suitable for using with IJC in developing
profiles?,,,or do I need some non-proprietary
spectrophotometer?,,,or for that matter, does anyone have any
specific recommendations of denistometers to use in conjunction with
IJC
Thanks
Kevin
Re: [Digital BW] IJC & EyeOne Spectrophotometer
2003-07-08 by Carl Schofield
I've been using the eye-one recently for this purpose.  Only problem is
you have to first read the patches in i1Share and then transfer the
data to a spreadsheet to calculate the density values and then input
the density values to IJC.  Would certainly be nice if IJC supported
the eye-one for direct input of density  data for linearization,
preferably in strip reading mode, rather than patch by patch.
StudioPrint does offer this capabilty, but only for the PC.
Carl
On Tuesday, July 8, 2003, at 10:21  AM, klog52756 wrote:
> Hi,
> IJC
> Thanks
> Kevin
Re: IJC & EyeOne Spectrophotometer
2003-07-09 by klog52756
Hi Carl,
Thanks for getting back.
Too bad the i1 spectrophotometer does not work well with IJC.
I am trying to find the best all-around solution to my BW & Archival
Color profiling needs.
So far I am leaning towards IJC for my BW (VM Ultratone) and i1 for
my archival color profiling.
Wish they would easily work together.
The spreadsheet that you mention, 1. Sounds complex, & 2. I assume
you did that yourself, & 3. IF I wanted to go that route, how would
I go about doing it?
BTW, I looked into StudioPrint as an option, but it does not support
my Epson 1280s
Thanks again,
Kevin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
problem is
input
supported
> Carl
> > Hi,
Eye
with
> > IJC
> > Thanks
> > Kevin
Re: [Digital BW] Re: IJC & EyeOne Spectrophotometer
2003-07-09 by Carl Schofield
Kevin
There are really no spectrophotometers or densitometers that work
directly with IJC.  You have to manually enter 26 density measurements
into IJC to linearize a profile.  StudioPrint is the only profiling
application I know of that interfaces directly with the eye-one and
other instruments.  You can make your own spreadsheet to transform the
L readings you get from the eye-one in i1Share quite easily by just
using the following equations to calculate density:
If L > 8
Y = ((L + 16)/116)^3
Else
Y = (L * 27)/24389
Density = -log10(Y)
Alternatively, Bruce Lindbloom has a spreadsheet that will make these
and other calculations for you from the spectral data:
http://www.brucelindbloom.com/downloads/SpectralCalculator10nm.xls.zip
GretagMacbeth also has an application that will work with the eye-one
on a PC (I use a Mac so haven't used it) and it will automatically
transfer the spectral data to a spreadsheet (like the one above).  It
is called KeyWizard and is available here:
http://www.gretagmacbeth.com/Source/
Gm.asp?part=Products&page=ProductsDisplay&id=6875&code=d&typ=product
Carl
On Wednesday, July 9, 2003, at 01:19  AM, klog52756 wrote:
> Hi Carl,
> my Epson 1280s
> Thanks again,
> Kevin
2003-07-11 by klog52756
Carl,
Thanks for the info & the links.
Doesn't sound insurmountable, transposing the data.  I'll have to
think it over.
I'm attracted to the i1, and it seems to be getting very good
reviews for profiling color.
Cheers
Kevin
<scho@m...> wrote:
> Kevin
measurements
profiling
and
just
> If L > 8
> Else
> Y = (L * 27)/24389
> Density = -log10(Y)
these
p
one
automatically
It
> Gm.asp?
> Carl
> > Hi Carl,
Archival
for
assume
would
support
> > my Epson 1280s
> > Thanks again,
> > Kevin
2003-07-11 by Tyler Boley
<scho@m...> wrote:
snip...
Unfortunately, you need the actual spectral data for Bruce's
spreadsheet to get to density. LAB values won't do it. I've as of yet
been unable to get any i1 software to export the spectral data, unless
something purchased (additionally) will do it.
i1 informs me density will eventually be built into i1Share, but it's
not high on the developement list.
I could be dumb as a post, but so far the i1 is becoming a paper
weight for density use.
Any info would be apreciated.
Tyler
2003-07-11 by Carl Schofield
Tyler,
You can view the spectral data in i1Share via the property inspector,
but as you noted there is no way to export the data, other than
manually writing the numbers down and then entering them in the
Lindbloom spreadsheet.  KeyWizard supposedly will import spectral data
directly into a spreadsheet from the Eye-One, but only on a PC.  I've
been calculating visual density from the L* values reported by i1Share
using the equations (from Bruce Lindbloom)  I posted and they work good
enough for my purposes.  I also contacted GM about getting density from
the Eye-One and this was their response:
> Unfortunately at this time it is not possible to measure density with
> the
> Eye-One (i1) instrument unless you have a third-party software
> application
> that supports density measurement (such as a large-format RIP program
> like
> BestColor or Onyx PosterShop).
> GretagMacbeth KeyWizard is no longer being developed. This application
> is
> still sold, but must be run on a Mac with OS 9.1 (it is not compatible
> with
> 9.2.2) or on a PC with Windows 2000.
> You can get spectral values from the i1 by using the free, unsupported
> utility, i1 Share 1.3 (available for download from www.i1color.com).
> From
> the spectral values or LAB values you can calculate density.
> GretagMacbeth
> has received a number of requests to include a density function in i1
> Share
> and is considering this for a future software release.
I told then to add my vote for including density in an updated i1Share,
but I'm not holding my breath.
Carl
> <scho@m...> wrote:
> snip...
> Tyler
Carl, I just figured it out. In measure tool, hit device/port. There
will be a check box for spectral. It will all be there when you export
as text, unsure of what happens when you as one of their silly i1share
formats. I have yet to find any decent documentation that tells me
what neato things "share" will do for me.
Try the above, you should be able to copy and paste it all into
Bruce's spreadsheet.
Just might solve it all, but I don't have time to play with it right
now. If you are on the colorsync list you will find other informed
responses to my questions about this there.
I have other "issues" with this package, do you mind sharing a little
off list mail?
Tyler
<scho@m...> wrote:
> Tyler,
> > the
> > application
> > like
application
> > is
compatible
> > with
> > From
> > GretagMacbeth
> > Share
> Carl
> > <scho@m...> wrote:
> > snip...
> > Tyler
2003-07-12 by Roy Harrington
Carl and Tyler,
I'm also interested in using the Eye-One for density measurements.
Is there any difference between just using the L value from i1share
and formulas that Carl posted, and using the full spectral data  in
Bruce's spreadsheet?  Does the spectral info give more accurate data
when you a primarily just interested in gray density?
How can you get the device into "scan" mode and get a whole string
of patch values?
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@t...>
> off list mail?
> Tyler
> <scho@m...> wrote:
> > Tyler,
2003-07-12 by Tyler Boley
Roy, I have not tried Carl's formulas, so he would be better qualified
to answer. Someone extremely knowledgeable told me I should be
linearizing via L values instead of density, so I've been anxious to
put that together but haven't had the time.
In order to scan, you must use MeasureTool, to get that you have to
download all of ProfileMakerPro and use MeasureTool in demo mode. I
would advise it as you will find it very useful.
The device itself seems fine, there are just some software
complexities to work out at first.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
<roy@h...> wrote:
> Carl and Tyler,
> of patch values?
> Roy
