Profile comparisons: IJC/OPM and QTR 2.0
2003-07-08 by Carl Schofield
I recently printed some 21 step grayscale wedges using profiles
generated in IJC/OPM and Roy's QTR 2.0 for comparison.  The step-wedges
were printed on EEM using an Epson 2200 with the standard UC inks
(matte black installed).  The profiles compared were an IJC/OPM neutral
profile made by Antonis (re-linearized for my printer), a 50:50 blend
of warm and cool IJC/OPM profiles, a QTR neutral profile, and a 50:50
blend of warm and cool QTR profiles.  The density measurements from the
step-wedges and curve plots are available in the form of an Appleworks
6 spreadsheet.  Antonis has placed an archive containing the IJC/OPM
and QTR profiles and the comparative spreadsheet in the group files
section:
QuadTone
%20RIP%20%28QTR%29/
All of the step-wedges printed using these profiles were very smooth
and differed only slightly in overall tone and degree of "neutrality".
The IJC/OPM profiles were uniformly slightly higher in density and
within either IJC/OPM or QTR the curves for the neutral and warm:cool
blended profiles were very similar.
If you would like a more "visual" way to evaluate the profiles take a
look at the Photoshop swatches or i1Share cxf files that were made from
the eye-one measurements of some of the step-wedges.  If you don't have
i1Share, it can be downloaded for free at the url given below and it is
available for both Mac and PC.  To view the data, just open the cxf
file in i1Share.  Alternatively, just place the Photoshop swatch into
the swatches folder using the following folder path for PS 7 (Adobe
Photoshop>Presets>Color Swatches>Adobe Photoshop Only) and then load it
to the swatches pallette in Photoshop.  Both methods will give you a
very accurate visual representation of the step wedge and you also have
access to the measurement data.  i1Share also has the tools to make
very detailed analyses and comparisons of the spectral data.  You can
download the swatches and/or cxf files from my filesharing site:
http://homepage.mac.com/scho/FileSharing2.html
http://www.i1color.com/freeware/
Carl
