Re: [Digital BW] Re: New (used) Epson 3000 Report : paper
2003-07-14 by Peter Marquis-Kyle
B. Alex Pettit Jr. wrote: > I installed the MIS FS/Gen4K inkset and > found it works flawless. You must be pleased! (wish I had a 3000....) > During performing a few test prints, however, > I accidentally loaded two sheets of Archival Matte: > slight banding was visible. I loaded one sheet : > Perfect. > > Thus I must conclude that some of the unsatisfactory > print banding I've noted is as much a result of a > paper's thickness as it is of its surface. Or perhaps the banding is not directly a result of paper thickness, but of print head alignment (which IS sensitive to paper thickness). For this reason, it is best to adjust alignment whenever you start printing on a paper with a different thickness. Peter Marquis-Kyle www.marquis-kyle.com.au
