New (used) Epson 3000 Report
2003-06-03 by B. Alex Pettit Jr.
Executive Summary : Wow !
I finally received this used Epson 3000
from a long truck journey from one end of the USA
to the other... Utah to Florida.
When I did a first nozzle check, all looked fine,
and the head alignment required no change.
Using the installed Cone Piezo inks and Driver,
the 8x10 prints on EAM, Epson Prem Luster, and
a few others looked quite similar to that obtained
with a Quad MIS set on my E2000P : very small banding,
but quite worthy of display. I was pleased at the
performance of an 'old technology' printer with
fat 12 uL dots.
Last night, I moved the paper guide margins to the extreme,
loaded in a 17x22 sheet of Somerset Velvet, and started the
process. One hour, 15 minutes a print was created -
but What a print: it is absolutely Flawless. Even when
using a loupe, there is no banding at all. And of course,
the Cone drivers do an outstanding job of making the dots
invisible also.
I am truly amazed. I don't know if this is just a lucky
print or what, but I can surely say that when an Epson 3000
works, it works very, very well.
I will print as much as I can with what is remaining of these
Cone Piezo inks to establish a basis of comparison for when
I swap to the MIS/MS set.
Happy new wide format owner,
Alex
Orlando Florida
Re: New (used) Epson 3000 Report
2003-07-13 by markroth61
Alex, just curious, was the paper you used here the Somerset Velvet
coated, or was it the uncoated? Best, Mark R.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "B. Alex Pettit
> fat 12 uL dots.
> invisible also.
> Alex
> Orlando Florida
2003-07-13 by B. Alex Pettit Jr.
That was the uncoated.
Alex
Re: New (used) Epson 3000 Report : paper
2003-07-14 by B. Alex Pettit Jr.
FYI,
I installed the MIS FS/Gen4K inkset and
found it works flawless.
During performing a few test prints, however,
I accidentally loaded two sheets of Archival Matte:
slight banding was visible. I loaded one sheet :
Perfect.
Thus I must conclude that some of the unsatisfactory
print banding I've noted is as much a result of a
paper's thickness as it is of its surface.
Best,
Alex
RE: [Digital BW] Re: New (used) Epson 3000 Report : paper
2003-07-14 by Paul Roark
Alex,
>...I accidentally loaded two sheets of Archival Matte:
>Perfect.
Before I bought a 7500, I used a 3000 to print 16x20" prints.  I'd slice off
17" of a 24" roll of EAM/EEM.  To get the paper to feed (especially with
it's curl) I'd put the paper between 2 dampened Kodak blotter papers
(sprayed with distilled water).  This softened the EAM and allowed very easy
front-tray feeding.  I think the softening of the EAM made it act more like
a very thin piece of paper and wrap around the roller without any problems.
At any rate, EAM & the 3000 was/is a very economical way to get some great
16 x 20 prints.
http://www.PaulRoark.com
