QuadtoneRIP 2.0 success at last
2003-07-28 by Phil Rose
Thanks to responses posted here and to several helpful emails from
Roy.
As Roy suggested, the error message displayed after trying to install
QTRIP
was not indicative of a failed installation. The program was in fact
installed in
spite of the "errors were detected...try again" message. My
subsequent
problem with Run-Quad-Profile was traced to the need for the BSD
subset,
which I discovered was missing from my OS 10.2.6 system. I was able
to add
BSD using the "Options" folder on the installation disk.
Now I'm able to print from PS 7.01 using QTRIP, and the results have
been
very promising.
BTW, I encountered the same difficulty as described by a previous
poster with
respect to running Roy's new "2200-cool" and "2200-warm"
ink-descriptor
files. Neither of them would work in Run-Quad-Profiles in spite
having correct
printer name, etc.  Each time the result was: "printer does not
exist."
As in the previous case, the required workaround was to transfer the
new ink
limit values to an existing file (e.g., 2200-neutral), and then
rename the file
accordingly.
 Phil
Re: QuadtoneRIP 2.0 success at last
2003-07-28 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Phil Rose" <pjrose@f...>
> Roy.
> QTRIP
> installed in
> subsequent
> subset,
> to add
> been
> very promising.
> poster with
> ink-descriptor
> having correct
> exist."
> new ink
> rename the file
> accordingly.
>  Phil
Great to hear that you got it working.  I'm curious about this
"printer does not exist"  error.  If you have a file that fails as
well as the one that works, could you email me them both so I can
see what the issue is.
Roy
