What is BO!!!!!? Bad odor?
2003-07-28 by luisvcool
Well? Pardon the ignorance. Thank you.
2003-07-28 by Peter Nelson
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "luisvcool" <lvictoria@t...> wrote: > Well? Pardon the ignorance. > > Thank you. It sure seems to leave one around here whenever we discuss it.<P> B.O. stands for "Black Only", and it's one of the settings in the printer driver for Epson printers. It tells the printer to ONLY use its black ink. Making black and white prints with an inkjet printer is very tricky because most inkjet printers have 6 or 7 inks and render shades of gray by combining them. Unfortunately getting them all to stay in balance across all tonal ranges, and to have the same tonal characteristics in all different kinds of light is like trying to TRAIN CATS TO MARCH IN FORMATION. A variety of alternatives exist - - - Using special third party inksets that ONLY have shades of gray (hextone or quadtone); using Raster Image Processors (RIPS) that have their own drivers and don't use all the different inks, in order to simplfy the problem; or outputting black and white digital files to conventional photographic paper via Lambda or Frontier technology, and B.O. printing. B.O. printing is the poor-man's way of making neutral black and white prints with an inkjet printer. The printer makes grayscales by printing black dots in various ratios to the underlying white paper. Here's a greatly enlarged sample: http://studio- nelson.com/inkjet/ijimages/edbo1a.jpg of a 5% black section of a wedge. Because the dots have to be spaced at quite a distance to achieve light grays they are quite visible and tend to create a noticable texturing in skin tones, light sky tones and other places on the print where a hextone print would be smooth. Some people don't find them objectionable, and some people even LIKE it, but most people switch to one of the alternatives as soon as they can afford it.
2003-07-28 by Austin Franklin
Hi Peter, > B.O. printing is the poor-man's way of making neutral black and > white prints with an inkjet printer. The printer makes grayscales > by printing black dots in various ratios to the underlying white > paper. Here's a greatly enlarged sample: http://studio- > nelson.com/inkjet/ijimages/edbo1a.jpg of a 5% black section of a > wedge. > > Because the dots have to be spaced at quite a distance to achieve > light grays they are quite visible and tend to create a noticeable > texturing in skin tones, light sky tones and other places on the > print where a hextone print would be smooth. Some people don't > find them objectionable, and some people even LIKE it, but most > people switch to one of the alternatives as soon as they can afford > it. Understood...but what is there to doing this aside from printing using the standard driver and selecting "Black Only" that was being heralded in another post? Regards, Austin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Austin Franklin" <darkroom@i...> wrote: > Understood...but what is there to doing this aside from > printing using the standard driver and selecting "Black > Only" that was being heralded in another post? Creating the right transfer function is ESSENTIAL, as it is in any digital printing practice. There are many ways of doing this - the Curve adjustment tool in Photoshop is one way, creating a Curve adjustment layer is another. Creating custom profiles is also a way to shape the transfer function. One of my new favorites is creating a set of custom gradient maps in Photoshop. I have ones for stretching the midtones, brightening the shadows, etc. All of these (and there are plenty of others) do the same thing - they determine how a particular RGB or grayscale value in the original image will be represented to the printer for output. Most of us have a test image we use. Mine consists of a continuous 0-255 wedge plus additional wedges with calibrated step functions in the shadow, midtone, and highlights, plus a sample image of a model with smooth slik tones from shadow to specular highlight. One of B.O.'s characteristics is that it produces a highly textured output (because of the dotting) in certain density ranges. One of the goals of your transfer function is either A. to place that texturing in parts of the image that are less prominent if you don't want to see it . . . or . . . B. emphasize it, if that's why you're using B.O. in the first place. The resident expert here on B.O. curve adjustment is Clayton Jones so he can give you detailed advice, depending on your goals.
2003-07-28 by johngeyles
> > Understood...but what is there to doing this aside from > > printing using the standard driver and selecting "Black > > Only" that was being heralded in another post? > > Creating the right transfer function is ESSENTIAL ... Yes, but at a more simple level (one of the main points of BO printing is to help newbies get started with minimal frustration), I'd answer: after you select "Black Only" you'll get a warning that it's suitable only for text; ignore this, and then go to "Advanced Settings" and bump the resoultion up to 1440 or 2880dpi. John
2003-07-29 by Austin Franklin
Peter, > Creating the right transfer function "transfer function"? I've never heard this called "transfer function"...where did you get that? > There are many ways of doing this - the > Curve adjustment tool in Photoshop is one way, creating a Curve > adjustment layer is another. Creating custom profiles is also a way > to shape the transfer function. One of my new favorites is creating > a set of custom gradient maps in Photoshop. I have ones for > stretching the midtones, brightening the shadows, etc. Everything you describe, from what I can tell, is simply tonal adjustment curve...and in simpler terms, a LUT (Look Up Table)...I'm not sure why you call it "transfer function", but I agree, that adjusting the tonal curve is how one would move the tones around to make them "fall" where you might find them more beneficial for different printing "methodologies"/dithering algorithms. > All of these (and there are plenty of others) do the same thing - > they determine how a particular RGB or grayscale value in the > original image will be represented to the printer for output. Perhaps this is what you meant, but were being more simplistic, but they don't "represent" anything to the printer, they "represent" it to the dithering algorithm, as the pixel values are converted to dots before being printed. Regards, Austin
2003-07-29 by Loris Medici
Please forgive my limited English understanding (and expression ability) but when one talks about a LUT I understand "a list consisting of limited amnt. of rows consisting from actual value -> converted value", if one talks about a transfer *function* there are no limited samples such a LUT but a "mathematical equation giving converted values for every possible actual values"... A tonal adjustment curve is a transfer function not a LUT (if it were so, we would have different set of curves for 8 and 16 bit modes - and the 16bit mode curve files' size would be 256K) Regards, Loris.
> -----Original Message----- > From: Austin Franklin [mailto:darkroom@...] > Sent: Tuesday, July 29, 2003 4:39 AM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: RE: [Digital BW] Re: What is BO!!!!!? Bad odor? > > ... > Everything you describe, from what I can tell, is simply > tonal adjustment curve...and in simpler terms, a LUT (Look Up > Table)...I'm not sure why you call it "transfer function", > ...
2003-07-29 by Peter Nelson
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Austin Franklin" <darkroom@i...> wrote: > Peter, > > > Creating the right transfer function > > "transfer function"? I've never heard this called "transfer > function"...where did you get that? That's the general term. Professionally I'm an engineer specializing in image processing. I say transfer function because it's more correct. Same reason I distinguish PPI from DPI. The problem with saying "curves" like lots of people here do is that some people are likely to only think in terms of Photoshop Curves tool or a Curve Adjustment Layer. Transfer function is the generic term for anything that defines the relationship between some input value and some output value. (or as we say in my R&D lab, "the relationship betweenthe the gazintas and gazoutas")<P> And I really should say "functionS" because there's actually a pipeline of transfer functions between the original image file and the dots of ink on the paper and they all need to be characterized.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Loris Medici" <lorism@t...> wrote: > Please forgive my limited English understanding (and expression ability) > but when one talks about a LUT I understand "a list consisting of > limited amnt. of rows consisting from actual value -> converted value", > if one talks about a transfer *function* there are no limited samples > such a LUT but a "mathematical equation giving converted values for > every possible actual values"... A tonal adjustment curve is a transfer > function not a LUT (if it were so, we would have different set of curves > for 8 and 16 bit modes - and the 16bit mode curve files' size would be > 256K) I work as an image-processing engineer in an R&D lab and there is incomplete agreement among my clleagues whether "transfer function" continous values - most people accept that it could be discrete values but a few prefer "mapping funtion" for anything implemented in a LUT. My guess is that most of the curves we see in Photoshop and profile-creation tools are actually implemented somewhere as LUTs simple because they are easy to implement that way, easy to edit, and readily accomodate pixels values that are already in a discrete domain (i.e., a pixel might be 253 or 254 but not 253.5). But, nonetheless, I chose the term "transfer function" instead of "curves" or "LUT", because I wanted a generic term that wasn't specific to a particular tool or implementation, and because it's a term regularly used in image and signal processing, which IS after all, what we're talking about here.
Peter, > > > Creating the right transfer function > > > > "transfer function"? I've never heard this called "transfer > > function"...where did you get that? > > That's the general term. Professionally I'm an engineer > specializing in image processing. I say transfer function because > it's more correct. I disagree that it's "more correct". "Transfer function" is far less precise term than LUT, or any more descriptive term for this...even tonal curve adjustment is more precise, as that IS what is happening, no matter how it's implemented. > Same reason I distinguish PPI from DPI. But these are two distinct things, and they should be distinguished. > And I really should say "functionS" because there's actually a > pipeline of transfer functions between the original image file and > the dots of ink on the paper and they all need to be characterized. I believe you're being overly pedantic calling it a "transfer function". It's too general a term, as it doesn't describe what is happening, and it's also not commonly used by imaging engineers when discussing simple tonal curve adjustment..we certainly don't say "well, we'll just use a transfer function here", we describe what is to happen, not that something is to happen. At least no one in my 25 years in the imaging industry has ever used that term for simple tonal curve adjustments. What you were describing is merely addition, typically implemented as a LUT. Yes, more happens after the tonal curve adjustment before ink gets to the paper, but we weren't talking about that. Regards, Austin
2003-07-30 by Peter Nelson
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Austin Franklin" <darkroom@i...> wrote: > I disagree that it's "more correct". "Transfer function" >is far less precise term than LUT Being less precise is EXACTLY why it's more correct. As I said in my prior post, I wanted a generic term. "Generic" and "precise" are opposites. The problem with LUT is that it's specific to a particular implementation, and furthermore we don't even know which, if **ANY** Photoshop or driver features are implemented with LUTs (although I suspect many are). So LUT is about as bad a term as you can get because there's no way to know when it's correct. The problems with "curves" is twofold - 1, The actual term "Curves" is used for some Photoshop tools, which makes it ambiguous because the reader doesn't know if you are speaking gererically or about a specific tool, and two, not all transfer functions are represented with curves. "Transfer Function" has two advantages: 1. It's generic - it describes ANY module, tool, or stage, where one set of values is mapped to another, thus encouraging users to think outside the box. 2. It is the technically correct term. I work in image processing and my colleagues and I were discussing this today. The consensus was that if we don't say "transfer funtion" then the only other correct term would be "mapping function". > What you were describing is merely addition, typically > implemented as a LUT. A LUT doesn't do addition; it takes an index and outputs a value. > Yes, more happens after the tonal curve adjustment before > ink gets to the paper, but we weren't talking about that. I was. That's why I brought it up. It's important for us to understand, and be able to manipulate as much as possible every step in the processing pipeline from the RGB values in our original image before Photoshop ever touches it, to when the printer sprays dots of ink on the paper.
2003-07-30 by Austin Franklin
Peter, > > I disagree that it's "more correct". "Transfer function" > >is far less precise term than LUT > > > Being less precise is EXACTLY why it's more correct. > > As I said in my prior post, I wanted a generic term. "Generic" > and "precise" are opposites. Come on. On one hand you say you're not generalizing, but on the other you say you are being generic? So you are trying to be generic, but pedantic? That makes no sense. > The problem with LUT is that it's specific to a particular > implementation, and furthermore we don't even know which, if **ANY** > Photoshop or driver features are implemented with LUTs (although I > suspect many are). So LUT is about as bad a term as you can get > because there's no way to know when it's correct. > > The problems with "curves" is twofold - 1, The actual term "Curves" > is used for some Photoshop tools, which makes it ambiguous because > the reader doesn't know if you are speaking gererically or about a > specific tool, and two, not all transfer functions are represented > with curves. > > "Transfer Function" has two advantages: > 1. It's generic - it describes ANY module, tool, or stage, where one > set of values is mapped to another, thus encouraging users to think > outside the box. No, that is NOT what transfer function means. It is means ANY operations, not simply "mapping". > 2. It is the technically correct term. I disagree. As I've said, it is TOO generic, and therefore describes not a single thing. Every operation that takes an input and gives an output is a transfer function. > I work in image processing Right, Peter, I understand, you've said that...and I also "work in" image processing and have for 25+ years. > and my colleagues and I were discussing this today. The consensus > was that if we don't say "transfer funtion" then the only other > correct term would be "mapping function". Mapping describes the function, and is not synonymous with transfer function, as transfer function encompasses far more than simply mapping function. BTW, can you describe a mapping function that can't be implemented in a LUT? > > What you were describing is merely addition, typically > > implemented as a LUT. > > A LUT doesn't do addition; it takes an index and outputs a value. A LUT very much so can "do" (provide the function of) addition, along with many other functions. Yes, it takes an index and outputs a value, but, as I said, many different operations can be implemented in a LUT. A LUT is typically how offset correction is done, especially in calibrated systems (such as a film scanner calibration for linearity), and that is in fact simple addition implemented as a LUT. When used as we are talking about, for storing tonal correction curves, it is providing a predetermined/deterministic output value for input value, and that output value was determined by addition. When you move the tonal curve, you are taking the original value (with is typically output == input, linear), and adding some offset to it, by moving the curve up or down. What gets put in as the new value in the indexed location is determined by the original value, plus that new offset, which is why I said the LUT is implementing addition. I've designed tonal curve manipulation functions, implemented in both hardware/firmware and done as pure software, and this is how they worked. Regards, Austin
