Re: [Digital BW] Photoshop Question - Burning In an Area In One Color
2003-08-01 by Jack M Kucy
Everything you do with the image in PS should be done in layers.
 Recommended
is using adjustment layers, since they weigh only a few kb.  Until you
get hold of
them do the duplicate layer.  Put the mask on it (at the beginning "see
all"), make
your adjustment on the whole image to the point the chosen areas look
good, but
a bit darker and more saturated than necessary.  Go back to the mask and
make
it "all invisible". You see that it disappears and you see uncorrected
image.  Now,
make your foreground color white and take a brush tool (experiment with
the size
and pressure, and paint with that brush the areas to be changed.  You
will see, that
the adjusted layer becomes visible just in these spots.
I would recommend going to some instructing books and learn about the
layers,
masks and channels.
You should always do changes to the image in a layer, having the
original state unchanged,
easy to return to if you want.
Good luck,
Jack
_________________________________________________
Jack M Kucy
JMK Gallery (www.jmk-gallery.com)
917-991-2096     jmk@...
Member of ASMP (www.asmp.org)
...a riveder le stelle
mfaphoto1949 wrote:
> I know how to do quite a few things is PS, but this I don't know.
> How do you burn in an area of a faded image to match the areas
> that are not faded? Or, how do you simply burn in an area of an
> image a certain color? Usually one color is faded and that
> causes the problems. If I knew how to burn in an area in one colr
> I could correct those areas of serious fading. If there is another
> way to do this let me know. I have a lot of negatives that need
> repair to one degree or another.
> I have tried going to Adjust>Hue/Saturation>Master and played
> with the various chanels. However, that changes the whole
> image and I don't aways need that.
> Thanks
> Russ Martin
2003-08-01 by mfaphoto@optonline.net
Thanks, I'll give it a try. I received another reply that I'll try also. It seems that this should be something that is easily done. Like use the eyedropper then go to burning tool and burn. Someday they will probably do that but for now, I guess I'll have to do it the roundabout way.
Russ
