Pyro Development for Negatives to be Scanned
2003-08-05 by jmoore172002
I apologize if this post is too much off topic.
I am interested in exploring Pyro development for my 4x5 sheet film
negatives to be scanned for Piezo printing. I shoot HP5+, process my
film in a Jobo CPP-2 rotary processor, scan on a Polaroid SprintScan
45 Ultra, then print using PiezographyBW on an Epson 1280 and an
Epson 7600. I plan on using the Pyro ABC (Rollo Pyro) formulation.
This will be my initial foray into Pyro development. I have a couple
of questions for any experienced Pyro users out there.
1) With respect to scanning, is the staining effect of Pyro
development beneficial or detrimental?
2) Any recommendations for starting development times for HP5+ and
Rollo Pyro?
3) In a rotary processor, should I pre-soak, and for how long?
Any input from experienced pyro users is very much appreciated.
Thanks.
Re: [Digital BW] Pyro Development for Negatives to be Scanned
2003-08-05 by D. Hill
I follow Chuck Farmer's methods with a bit of
personalization when developing PMK in a Jobo found
here: http://www.jobo-usa.com/jq/jq9502.htm
It is a very fine write-up and handles most of the
developing/presoak questions - I can't really add
more.  However, I have found pyro to be very
compatible with digital processing and methods.
Don
> of Pyro
> times for HP5+ and
> Rollo Pyro?
> how long?
> appreciated.
> Thanks.
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
RE: [Digital BW] Pyro Development for Negatives to be Scanned
2003-08-05 by Martin Wesley
> From: jmoore172002 [mailto:jeffmoore17@...]
> Sent: Monday, August 04, 2003 9:22 PM
> Subject: [Digital BW] Pyro Development for Negatives to be Scanned
> Rollo Pyro?
> Thanks.
Jeff,
I have been using Pyro in a Jobo CPA-2 for the last 11 or so years. I mostly
use  my own PBC pyro formula or occasionally PMK with the nitrogen blanket
set-up as described in Gordon Hutchings "The Book of Pyro." I insert sheet
film dry into the drum and use a single 5 minute presoak with tap water. All
the benefits of Pyro for enlarger printing seem to carry over to digital
scanning as well and I have not found any need to change my development. I
shoot FP4+ and Tmax 400 in 4x5.
I also develop 35mm and 120 film in reels with Pyro on the Jobo with
nitrogen blanketing. Works great.
I was not able to entirely eliminate mottling in the Jobo without the
nitrogen purge. The Chuck Farmer method Don mentioned in his post sounds
promising but rather time consuming compared to using the purge. I am not
familiar with the Rollo formula.
During scanning with a Howtek D4000 I use just the blue channel for 16-bit
grayscale to take advantage of the yellow image stain density. Occasionally
I will scan in RGB and play with the channel mixer if it is a problem neg.
Martin Wesley
2003-08-05 by wilfredm71047
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Martin Wesley"
<mwesley250@e...> wrote:
> > From: jmoore172002 [mailto:jeffmoore17@c...]
film
my
SprintScan
couple
> > Rollo Pyro?
> > Thanks.
> Jeff,
I mostly
blanket
insert sheet
water. All
digital
development. I
sounds
am not
16-bit
Occasionally
problem neg.
> Martin Wesley
>I have been successful with Pyro and have gotten most of my info
>from Gordon Hutchings "The Book of Pyro". I,like Martin use a 5
>minute pre-soak. Instead of the nitron burst, I found that two very
>short,"1 minute and 30 second development at 80degrees" worked well
>for me. One thing that gave me trouble was these splotches on the
>the film after completing the process. I found them to be where
>prewet water splashed on the film while introducing the water into
>the drum. Everywhere a drop of water hit the dry film, even though
>that drop didn't stay there for a fraction of a second, it caused
>that spot to show in the dry negative. To eleminate this I would
>take the drum with no lid in place, and push it into a 2 gallon pale
>full of my pre-soak water. A steady, and slightly rapid sinking of
>the entire drum flooded the film fast enough as not to allow any
>part of the film to remain wet before all of it was wet. Then I
>would install the lid and tap the bottom of the drum on the counter
>to eleminate any air bubbles. This >eleminated the splotches for me.
>I call it the Wilfred Dunk. He,He.
    Wilfred Smith.
RE: Pyro Development for Negatives to be Scanned
2003-08-05 by adounoucos@aol.com
While you're exploring Pyro development, look at the July/August issue of
Photo Techniques which has an article 'How I created my special Monochrome
Developer". The author, Barry Thornton refers to Pyro and other techniques and came
up with his own formula.   He has a web site   if you can't find this issue:
     www.barrythornton.com
Let us know how you do.
Angelo Dounoucos
Re: Pyro Development for Negatives to be Scanned
2003-08-05 by B. Alex Pettit Jr.
I have been using Barry's Exactol Lux and Archivex fixer with Tmax100.
The Exactol Lux is a mild staining and sharpening developer.
In looking at the emulsion side of the film at an angle, the
ExactolLux processed film shows a very strong BasRelief in comparison
to TmaxRS developer- the 'on film sharpening' effect. It scans well in
my SprintScan 45.
Consider Barry's book Elements of Transition - good ideas on film
processing, scanning, a few Photoshop tweaks and Piezo printing.
Best,
Alex
this issue:
> Angelo Dounoucos
> From: wilfredm71047 [mailto:wilfredm@...]
> Sent: Tuesday, August 05, 2003 6:43 AM
> Subject: Re: [Digital BW] Pyro Development for Negatives to be Scanned
(snip earlier)
>     Wilfred Smith.
Wilfred,
Thanks for the "Dunk" tip. I know people have problems with water spotting
during the presoak fill including Gordon Hutchings. For some reason (local
water?) I have never encountered it. I just pour a gallon or so of water in
through the lid's fill port with the drum slightly tilted to one side. Your
filling method sounds so easy though I'll give it a try.
With the high temp, short development time, how do you manage your N-1, N-2,
N-3, etc. developments?
Martin
2003-08-06 by Ken Carney
That may be what I'm doing wrong.  I can get fair RGB or gray channel scans
with PMK negs, and not very good scans at all with Rollo.  Back to the
drawing board.  Thanks.
  --Ken Carney
    www.kencarney.com
Occasionally
> Martin Wesley
2003-08-06 by Martin Wesley
> From: Martin Wesley [mailto:mwesley250@...]
> Sent: Monday, August 04, 2003 11:11 PM
> Subject: RE: [Digital BW] Pyro Development for Negatives to be Scanned
> I insert sheet
> water.
Ooops! Have to correct myself here due to senile dementia and too much time
making prints and not enough time developing film! I presoak for 5 minutes
by adding a liter of distilled water while the dry drum is on the Jobo with
the rotation set to about "4". At the end of this time I empty the drum and
fill it completely with tape water while off the Jobo. I then put it back on
the Jobo and empty it with the nitrogen purge running so that the water is
displaced by the nitrogen. This leaves me with a virtually oxygen free
environment in the drum for development. I reduce the nitrogen flow and keep
it going through out the development step.
Martin Wesley
2003-08-06 by jymbo4600
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jmoore172002"
film
my
SprintScan
couple
If you go to www.barrythornton.com he has a new Pyro formula that he
mixes specially for scanning. I have had great luck with PMK for
years, with no blotching and I tank develop by hand. Even my old
Diana negatives scan beautifully. Thornton's developer does a lovely
job too. Jim Weekes
> Rollo Pyro?
> Thanks.
2003-08-06 by photographyworks
If you use a rotary drum machine go with PMK. After the first half
of total development time substitute with fresh developer to avoid
getting  non actinic stain. The results will be awesome in every
respect and especially for scanning.
Hope this helps.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jymbo4600"
<jymbo46@b...> wrote:
> --- In
> film
process
> my
> SprintScan
formulation.
> couple
he
lovely
> job too. Jim Weekes
and
> > Rollo Pyro?
> > Thanks.
