Can I slightly modify Quadtone file w/o starting over.
2003-08-19 by John Vitollo
With the latest Quadtone I'm printing with Piezotone, Photorag and the 1160-fs file.
Most tones are right-on when compared to the monitor - the dither is excellent by
the way. But anything above 5% K burns out - only paper white is visible. Instead of
doing a completely new profile I was wondering if I can modify information in the
original 1160-fs file to hold the highlights? If someone could point me in the right
direction I would really appreciate it.
Here's the file info:
#  quadtone curve descriptor file
# the printer name
# the curve name
#   no spaces or special characters, except - or _  (dash or underscore)
PRINTER=Quad_1160
CURVE_NAME=1160-fs
CALIBRATION=NO
GRAPH_CURVE=YES
# number of inks must be 4, 6, or 7
# the ink limits are percentages
#   usually they are all the same but they can be individually set
N_OF_INKS=4
DEFAULT_INK_LIMIT=80
LIMIT_K=
BOOST_K=100
LIMIT_C=
LIMIT_M=
LIMIT_Y=
LIMIT_LC=
LIMIT_LM=
LIMIT_LK=
#  Describe Usage of each Ink: K,C,M,Y,LC,LM,LK
#    All Inks of Printer must be listed
# Gray Partition Information
#  use ink names: K,C,M,Y,LC,LM,LK
N_OF_GRAY_PARTS=4
GRAY_INK_1=K
GRAY_VAL_1=100
GRAY_INK_2=C
GRAY_VAL_2=44
GRAY_INK_3=M
GRAY_VAL_3=12
GRAY_INK_4=Y
GRAY_VAL_4=5
GRAY_INK_5=
GRAY_VAL_5=
GRAY_INK_6=
GRAY_VAL_6=
GRAY_INK_7=
GRAY_VAL_7=
GRAY_HIGHLIGHT=11
GRAY_SHADOW=11
GRAY_OVERLAP=50
GRAY_GAMMA=1
GRAY_CURVE=
# Toner Partition Information
N_OF_TONER_PARTS=0
TONER_INK_1=
TONER_VAL_1=
TONER_INK_2=
TONER_VAL_2=
TONER_HIGHLIGHT=11
TONER_SHADOW=11
TONER_GAMMA=1
TONER_CURVE=
# Unused Inks
N_OF_UNUSED=0
UNUSED_INK_1=
UNUSED_INK_2=
UNUSED_INK_3=
UNUSED_INK_4=
# the following is a special UltraChrome ink flag
# it copies the light-black curves to the light-cyan and light-magenta inks.
# this insures that the LC and LM inks are used to directly neutralize
# the color of the light-black.
# the color balance of inks is controlled by the LIMIT_... values above.
UC_NEUTRALIZER=NO
Re: [Digital BW] Can I slightly modify Quadtone file w/o starting over.
2003-08-20 by Carl Schofield
John,
Try lowering the GRAY_HIGHLIGHT=11 to a lower value.  I think that the
higher this number is the steeper the curve in the highlights.  I don't
know what the value should be for your case but go low, say 2, and then
raise it if necessary.  If you are going to linearize the curve anyway,
just set low values for both highlight and shadow.
Carl
On Tuesday, August 19, 2003, at 06:52  PM, John Vitollo wrote:
> Hi,
> 1160-fs file.
> excellent by
> visible. Instead of
> information in the
> me in the right
> # the printer name
> # the curve name
> underscore)
> PRINTER=Quad_1160
> CURVE_NAME=1160-fs
> CALIBRATION=NO
> GRAPH_CURVE=YES
> N_OF_INKS=4
> LIMIT_K=
> BOOST_K=100
> LIMIT_C=
> LIMIT_M=
> LIMIT_Y=
> LIMIT_LC=
> LIMIT_LM=
> LIMIT_LK=
> N_OF_GRAY_PARTS=4
> GRAY_INK_1=K
> GRAY_VAL_1=100
> GRAY_INK_2=C
> GRAY_VAL_2=44
> GRAY_INK_3=M
> GRAY_VAL_3=12
> GRAY_INK_4=Y
> GRAY_VAL_4=5
> GRAY_INK_5=
> GRAY_VAL_5=
> GRAY_INK_6=
> GRAY_VAL_6=
> GRAY_INK_7=
> GRAY_VAL_7=
> GRAY_HIGHLIGHT=11
> GRAY_SHADOW=11
> GRAY_OVERLAP=50
> GRAY_GAMMA=1
> GRAY_CURVE=
> N_OF_TONER_PARTS=0
> TONER_INK_1=
> TONER_VAL_1=
> TONER_INK_2=
> TONER_VAL_2=
> TONER_HIGHLIGHT=11
> TONER_SHADOW=11
> TONER_GAMMA=1
> TONER_CURVE=
> # Unused Inks
> N_OF_UNUSED=0
> UNUSED_INK_1=
> UNUSED_INK_2=
> UNUSED_INK_3=
> UNUSED_INK_4=
> inks.
> above.
> UC_NEUTRALIZER=NO
> Buy Ink Cartridges or Refill Kits for Your HP, Epson, Canon or Lexmark
> Printer at Myinks.com. Free s/h on orders $50 or more to the US &
> Canada. http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/l.m7sD/LIdGAA/qnsNAA/ucIolB/TM
> Please visit the Group Homepage to check the Files, Bookmarks, Polls
> and other resources as they are often being updated. The page is at:
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> - As the topic of a thread changes remember to change the subject
> header.
> - Good manners are required at all time. No personal attacks or flames
> - Before posting a question, search the message archives and the
> various resources on the homepage.
> Your use of Yahoo! Groups is subject to
