Re: Printer for Piezography
2003-08-23 by Mitch Alland
For: Arthur Fink > If the 2200 with its regular ink set is fine, then I'd have the > advantage > of not needing to dedicate one printer to B&W. Or ... is that a false > economy? I used to print B&W on the 1160+Piezography and color with the 1280 and the Epson Driver. Now I am using the 7600 and ImagePrint. (The 7600 is functionally the same as the 2200 except that it costs some $70-80 in wasted ink to switch from Photo Black, for printing on glossy-type paper, to Matte Black, for printing on matte-type black paper.) With the latest version of ImagePrint (5.6), I find that my color prints are better than those using either the Epson Driver or the fine Atkinson profiles. I particularly like printing on Epson Premium Semi-Matte (a glossy-type paper) on which I recently made a series of prints for an exhibition whose general sharpness, richness of backs and color subtlety and smoothness I found that I could not duplicate after switch to Matte Black and EEM and Photo Rag. As for B&W, I find that my prints using Matte Black on EEM and Photo Rag are every bit as good as the prints I used to make on the same papers with the 1160+Piezography. And I have the advantage of being able to make subtle changes in the tone of the print, say from warm to selenium, using the ImagePrint TintPicker. [B&W prints using Photo Black and glossy-type papers are unacceptable because they exhibit "bronzing."] The only problem I have is the $70-80 cost of changing back and forth between the Photo Black and Matte Black inks -- a problem that you won't have with the 2200. But I hope that there soon will be some new papers that will produce good B&W with the Photo Black ink, such as the forthcoming Oriental Seagull paper. --MItch/Potomac, MD
