Arches Infinity Review on dpandi.com
2003-08-24 by shashinka@aol.com
Hello: A review of Arches Infinity Standard and Natural White papers by me and Harald Johnson is available at the following link: http://www.dpandi.com/newsreviews/reviews/ai/index.html All the best! Andrew Darlow [Non-text portions of this message have been removed]
2003-08-24 by Tyler Boley
I'm less and less inclined to get into differences of opinion on the internet these days, but with this I'll make an exception. The announcement of this review has been cross posted on every Epson related list I am on, that and the fact that my tests with the paper were less than stunning move me to respond. Considering the high price of this stuff, some alternate views are needed. This paper has some eccentricities. The way it takes ink reminds me very much of some papers I've tried that have gelatin coatings like a long gone paper from Bulldog (interestingly call PhotoRag if I recall), Oce watercolor paper (sold under different names different places), and Luminos Charcoal R. This coating takes ink slowing, so it stays wet on the surface of the paper longer than coatings used by most other papers. This has several consequences. Firstly, you may have pizza wheel tracks since areas of high ink load will be very puddled on the surface as the paper moves under the wheels. When the ink dries on the surface (rather than absorbed), high ink load areas have a different reflective quality than the rest of the paper. So blacks or near blacks will only appear their deepest under the right lighting, it's related to the bronzing effect others refer to with glossy papers. It has a definite ink load limit, beyond which you will get mottle, bleed, possible pizza wheel tracks and the above mentioned effect. Compared to the Hahnemühle line of papers, which are still the ones to beat in terms of objective performance in the art paper category, it displays a lower Dmax and gamut. All of that said, the Dmax and gamut are not bad compared to something like Museo. It also presents the subtle hues of quad sets differently, another quality I've seen in papers with unusual coatings. For color you will definitely need good profiles, I've tried the Nash 9600 profiles on Arches' site, and found some problems. It moves the warmer quad inks to a more uniformly neutral hue, I haven't tried something like the Selenium inks with it. I haven't tested, but I'll bet this paper takes dyes better than pigments. BUT- It will produce beautiful prints. Since it has a nice surface and color, there are images that look very nice on it if the qualities they require fall within the paper's abilities. In the category of coated fine art inkjet papers, there are others less expensive that perform better under all circumstances. I strongly suggest that, considering it's expense, you find some samples and do some tests. If your particular images sing on it and nothing else, and you are a trust fund kid, you're good. I wish there were more options, but the Hahnemühle papers remain (unfortunately) the papers to beat for all around performance in this category of papers that I have tried. I don't have a lot of test numbers to report since I don't write articles. Steve Meyers and I fooled with it enough for me to know it's not going to work for me so testing stopped. Life is short. I should add that after seeing a few samples of the paper, I was very excited to try it. That was before the price was announced of course. Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, shashinka@a... wrote: > Hello: > > A review of Arches Infinity Standard and Natural White papers by me and
> Harald Johnson is available at the following link: > > http://www.dpandi.com/newsreviews/reviews/ai/index.html > > All the best! > > Andrew Darlow
2003-08-25 by john eckenrode
since we're talking about the arches paper here is my evaluation after working with it for some time now. good: great feel, weight and texture, the hefty weight (250gsm) and stiff construction gets rid of curl and buckling i like the slightly warm base, its not concord rag warm, but is is a natural color, the lack of oba's soothes my mind-just my own personal hang up it prints very smoothly with UC inks on a 2200 doesn't flake, so far i had a profile made by cathy stratton and the color gamut and accuracy is great, my print moniter match is very very close (i use a LaCie electron blue iv calibrated with monaco ez color and sensor) bad: way too expensive, but that is a problem with many higher end papers my quad b&w printing with MIS VM is inconsistant, my tones have a notable eggplantish color shift, not terrible, not what i like either. i just switched to ultratones and have not tried that yet. for quads i have had much better luck with hahnemuhle, hawk mountain and museum digital art papers. (unfortunately museum flakes too much) like tyler said, it can build up denstity in the blacks that appears to sit on the surface of the paper, it usually doesn't but it can, when it does there is some bronzing like characteristics, nothing like ultrachromes on glossy papers but still not desirable. i am going to try dialing back the ink coverage a bit on my few troublesome images to see if that corrects things. without profiling the paper it can be a little tough to get right, the arches canned profile is okay but it is a snick green and it plugs shadows. my custom profile appears to have fixed this problem. other profiles like lepp or my own monaco quick profiles or a random eem profile are a mess (plugged shadows, too much ink build up) it also smells bad when it first comes out of the box, that goes away after a bit though so sorry if i rambled, just thought i'd share my experiences with the paper. i use it for color images i really really like. for quads its not my first choice by any means. i am going to try the entrada natural finish paper here shortly and see where that leads. the price and early reports are encouraging. john eckenrode __________________________________ Do you Yahoo!? Yahoo! SiteBuilder - Free, easy-to-use web site design software http://sitebuilder.yahoo.com
2003-08-25 by shashinka@aol.com
> I'm less and less inclined to get into differences of opinion on the > internet these days, but with this I'll make an exception. The > announcement of this review has been cross posted on every Epson > related list I am on, that and the fact that my tests with the paper > were less than stunning move me to respond. > Considering the high price of this stuff, some alternate views are > needed... > snip > > Tyler > Hi Tyler: Thank you for your comments from personal experience. I think I covered some of the shortcomings you mentioned by ink laydown in the shadow areas, and I saw them primarily with the textured 355gsm version with a heavy ink load. Harald's prints on a 1280 with OEM dyes didn't exhibit any pizza wheels, and I tested the Ultrachromes on a 7600 so I only had the roller mark problem when trying to print the back of the sheet, which I mentioned in the review. I also didn't print with any quadtones, but the Ultrachrome OEM's through Imageprint's BW profiles rendered very nicely to my eye, as did black ink only printing. The cost is of course an issue, but the 17x22 pricing wasn't bad in my opinion(about $6 street cost for the 230gsm sheets). All the best! Andrew Darlow [Non-text portions of this message have been removed]
