not happy with GIMP dither patterns in highlights
2003-08-24 by J Michael Sullivan
Dear List,
Am quite happy with QuadToneRIP neutrality, but what concerns me are the dither
patterns shipped with GIMP - specifically in the lightest highlights I can see
significant "roughness" in the dither patterns especially in subtle transistions from
light grey to lighter grey (e.g. faces)
I have tried most of the resolution media choices and still am not happy with any of
them.  "1440x720 DPI Four Pass Unidirectional" is the one I think is best of the ones I
have tested, but still leaves me wishing for a better pattern.
Anyone else have a problem with the GIMP patterns?
MJS
Re: [Digital BW] not happy with GIMP dither patterns in highlights
2003-08-24 by Carl Schofield
Michael,
Which printer and inkset are you using?  I'm using the 2200 (currently
with MIS Ultratones) and the tonal transitions are very smooth, with no
apparent "roughness".  I was able to see highlight dots in some prints
when using the UC inks, but just adding the UT light gray solved that
problem and with the full UT inkset the tones are even better across
the scale.  Are you using the "Adaptive Hybrid" dither pattern?  That
one works fine for me at 1440x720 Highest Resolution.  Another dither
pattern that looks very good is "EvenTone", but it does change the
overall print tone and I would have to re-profile to correct the tone.
Carl
On Sunday, August 24, 2003, at 03:47  PM, J Michael Sullivan wrote:
> Dear List,
> the dither
> can see
> transistions from
> happy with any of
> best of the ones I
> MJS
Re: not happy with GIMP dither patterns in highlights
2003-08-24 by Roy Harrington
Hi Michael,
As I remember you are using a 9600.  I've done some work with a 7600
and I think I saw what you're calling roughness.  I don't think its the dither
pattern but instead it's the ink droplet size.
I've been looking at the printer documentation and it appears that there is
an even smaller droplet size available.  The version of gimp-print I'm using
doesn't support that a later version does.  So I'm going to try and retrofit
that small droplet size into the gimp-print I'm using.
I have a short timeslot to try this on the 7600 this coming week.  If the
simple fix works, I can make it available very soon -- but if I need to
upgrade the whole gimp-print version it'll take longer.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield <scho@m...>
wrote:
> Michael,
> Carl
> > Dear List,
> > the dither
> > can see
> > transistions from
> > happy with any of
> > best of the ones I
> > MJS
2003-08-25 by shashinka@aol.com
In a message dated 8/24/03 3:56:06 PM, michael@... writes:
> Dear List,
> dither
> see
> transistions from
> with any of
> the ones I
Hi Michael;
Have you done the full head alignment routine on the same paper that you
usually print on? It takes about 20 minutes and requires a loupe for the vertical
line segments. That might get things into better shape.
All the best!
Andrew Darlow
