EAM turns yellow!
EAM turns yellow!
2003-08-30 by Mark Hahn
was headed out the door with a portfolio of quadtone prints (all in
plastic sleaves).  then I noticed that the edge at the open end of
the sleave on all the prints had turned yellow!  also, a number of
prints that had been stacked up for a few weeks all had gone yellow!
This crap is certainly not archival.  What is the next step for
archival quality and the same printing results?  I am getting worried
about the prints that I have already sold (with my claims of archival
quality etc.).
thanks,
mark
Re: EAM turns yellow!
2003-08-30 by harrisimages
Mark,
If you are using EAM, it might be old stock since EAM has been
replaced with EEM.  Both papers have brightners which make the paper
appear whiter.  If you expose this paper to strong sunlight or let
the paper get a little age on it, the brightners will fade and the
natural yellowish paper base will show up.  Generally, this color
should be stable.  However, the paper is not archival....that's why
Epson changed the name to EEM.  The paper is not acid free and after
about 30 years, the acid should start attacking the paper.
If you like the way your images look on EAM/EEM, you might use Epson
Velvet Fine Art paper for your print sales....it has the same
coating, but the brightners appear to be stable and the paper is
acid free.  This paper is the same paper as Somerset Photo Enhanced,
but it has the Epson coating.
Many printers are using PhotoRag....but this paper prints with a
lower Dmax if you are using Ultrachrome inks.  If you are using
PiezoTone inks, PhotoRag gives a higher Dmax with this ink, so this
would be a good choice for your fine art prints.
There are other acid free fine art papers available.  Several online
vendors sell them.
Ron
www.harrisimages.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark Hahn"
in
yellow!
worried
archival
> quality etc.).
> thanks,
> mark
2003-08-31 by Clayton Jones
Hello Mark,
yellow!
The yellowing of EAM has been discussed in this forum for many months.
>What is the next step for archival quality and the same printing
>results?
I have found that PhotoRag is very close to EAM, requiring very
little, if any, change.  It is also widely regarded as one of the best
cotton papers.  When I first got into this I tried samples of all the
then available papers and liked PR the best.  It was a happy
coincidence that it is nearly identical to EAM in tonality, so I use
EAM for proofing and PR for final prints.
Clayton
RE: [Digital BW] EAM turns yellow!
2003-08-31 by Ed Mathews
> From: Mark Hahn [mailto:markhahn2000@...]
> Sent: Saturday, August 30, 2003 2:56 PM
> Subject: [Digital BW] EAM turns yellow!
I've heard this so many times about EAM.  I've never used it, mainly
because Heavy Weight Matte is cheaper and I keep hearing that HWM is
actually rated higher for it's archival qualities.  People have sent me
prints made on EAM and I see nothing special about the look or feel of
the paper.  What is it that people love so much about it?
Ed
http://lightandsilver.com
Re: [Digital BW] EAM turns yellow!
2003-08-31 by Phil Rose
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ed
Mathews" <ed@l...> wrote:
> > From: Mark Hahn [mailto:markhahn2000@y...]
yellow!
mainly
that HWM is
sent me
or feel of
The yellowing of Epson Archival Matte paper is what had caused
Epson to rename the product as "Enhanced Matte". The
discoloration was presumably (and ironically) caused by the
paper's optical brighteners, which I assume is still present in the
Enhanced Matte (EEM). The Heavyweight Matte is probably just
as good for fade-resistance but without the yellowing problem. It
is not quite as bright nor as heavy as Enhanced Matte, but  prints
very similarly, and as you say--is cheaper.
Phil
2003-08-31 by Thomas Fors
On Sat, 30 Aug 2003, Ed Mathews wrote:
> People have sent me
The blacks.  I haven't found anything yet that beats its Dmax when using UltraChrome inks.
--Tom
RE: [Digital BW] Re: EAM turns yellow!
2003-08-31 by Paul Roark
Ron,
>... the paper is not archival... The paper is not acid free and after
Note that Wilhelm appears to have changed his prediction for EEM.  He now
gives the paper a 110 year dark storage estimated life.  See:
http://www.wilhelm-research.com/ep9600%20print%20permanence.html
http://www.PaulRoark.com
Hi Ron,
I remember you recommending this on another list before, but I haven't had a chance to try Velvet Fine Art yet.  I did just get some of the Epson branded Somerset Velvet and haven't opened it yet.  Do you happen to know how Epson's Somerset Velvet differs from Velvet Fine Art?
Thanks
--Tom
2003-08-31 by Mark Hahn
Thanks all.  I guess you ignore a lot of problems until they effect
you.  I'll try some PR if you're not seeing any yellowing.  This was
a last minute thing and I probably over reacted a bit... only
actually had to pull one photo that I really wanted to show... also
realized that the yellowing was mostly apparent under incandecent
light and not the cooler gallery lighting so no one notice the more
minor edge yellowing... but it was a rude shock.  Sure, the paper is
old stock... something like 6-12 months old, but come on, when it is
called "archival matte" you wouldn't think it would go bad that
fast.  The other issue is that my air conditioner was broken and I
was on the swamp cooler for the last week which raises the humitidity
in the house which was probably the real driver.
mark
best
2003-08-31 by harrisimages
Paul,
I had noticed Wilhelm's update.....but, what does it mean....is he
ignoring the acid in the paper and the burning out of the
brightners?  Has Epson recently changed the EEM recipe?  Or is he
only looking at the stability of the ink on the EEM coating.  And,
exactly what does he mean by B&W printing using full color
Ultrachrome inks?  How is he making these B&W prints?  Is he using
the "monochrome" option in the Epson driver....note the "monocrhome"
choice is not the same as choosing "black ink only." Or is he using
a RIP like ImagePrint, which doesn't use Yellow in printing B&W
using color inks....thereby, increasing print life.  If he is not
using ImagePrint, then how much longer can we expect ImagePrint B&W
prints to last? Does Wilhelm publish more than just numbers of years
anwhere? Can you shed any light on these questions?
In my own very harsh Louisiana sun tests of a couple of weeks
duration with B&W prints using a 2200 with Ultrachrome inks and
ImagePrint 5.5 on both Epson Enhanced Matte and Epson Velvet Fine
Art, the image appears to be very stable.  After a few days the
brightners burn out of EEM and the paper takes on a faint yellowish
color, which seems to become stable after a few days.  I see almost
none of this with EVFA, which has the same coating as EEM and which
is acid free.
Thanks!
Ron
<paul.roark@v...> wrote:
> Ron,
after
He now
> Paul
I noticed that too and was very surprised.
His notes indicate that he runs his dark storage test at a constant relative humidity of 50% and that higher temperatures and higher RH could cause accelerated yellowing.  The big unknown here is how much does yellowing accelerate with higher RH.
Also, his dark storage test applies to prints that are framed, boxed, or sleeved to protect them from the open atmosphere.  He does mention that low-level air pollutants may cause, "significant yellowing within a relatively short period of time."  Again, we don't know what level of pollutants or how much it accelerates yellowing.
The only test where he uses unframed prints is his "bare-bulb" test; EEM B&W prints still did rather well in it, but again that uses a constant RH this time at 60%.  Also, I would bet that the air in his test lab is of fairly high quality.
I think the air quality issue could explain why people see results that often appear contradictory to Wilhelm's published data.
--Tom
That would do it.  Check out the notes for Wilhelm's tests at the link that Paul provided.
--Tom
Re: [Digital BW] Re: EAM turns yellow!
2003-08-31 by sdmey4@aol.com
In a message dated 8/31/2003 8:49:30 AM Pacific Daylight Time, tom@...
writes:
I doubt very much much Epson is Buying Sumerset Enhanced and using an"Epson
coating" This rebranding of papers with a new name and the resellers claiming
they use there own special coating turned out to be all BS.
There where several renamed versions of the entire Hahnemuhle line of papers,
and they where and are all the same regardless who's name was on the package.
Even Ilford's lastest Fine art paper is Hahnemuhles William Turner!
Tom wrote, in part:
>>He now gives the paper a 110 year dark storage estimated life.  See:
>I noticed that too and was very surprised.    His notes indicate
>much does yellowing accelerate with higher RH.  ...
I agree.  In my earlier post on this I noted the cynic in me wondered
whether the paper had changed ... or something else.  The something else
could well be the testing standards.
I think the bottom line is that Epson Enhance (aka "Archival") Matte is not
archival.
>pollutants or how much it accelerates yellowing.  ...
Yep, lots of unknowns in these tests and predictions.
Stick with buffered, un-brightened cotton for the maximum life.
Ron wrote, in part:
>brighteners?
I assume he must have standards that allow the usual brightener yellowing,
because lots of even cotton papers have brighteners and, in my tests, yellow
the same as EEM/EAM.  Usually after this initial yellowing -- which really
just turns the paper a cream color similar to some un-brightened papers --
the paper becomes stable, at least in my fade tests.  As such, I've assumed,
and Epson representatives have said, that the yellowing Wilhelm noted in the
earlier 30-year prediction was due to acid attacking the paper.
>brighteners burn out of EEM and the paper takes on a faint yellowish
>is acid free.
That seems consistent with what I see.  I think the Epson "Fine Art"
papers do not have brighteners in them.
I like EEM for display and general printing.  However, I'd never sell a
display print on that paper or use the paper for re-producing old family
photos, given what we now know.
2003-08-31 by D. Hill
So if EEM is just for proofing - is anyone using
Heavyweight Matte for their work?  I prefer its color
base over EEM, and if I remember correctly it has
pretty much the same storage/archival potential.
That and the price is spectacular, as well as the
blacks - very rich and velvety.
Don
> > People have sent me
> the look or feel of
> about it?
> --Tom
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
Hahnemuhle
I've seen something to the effect, but does anyone
know of a chart or cross reference list of Hahnemuhle
repackaged papers?
Don
Do you Yahoo!?
Tom,
Epson Velvet Fine Art paper has the same coating as EEM.  This is
not true of Epson's Somerset Velvet (I haven't tried this paper
myself.).  If you are printing with the Epson 2200 using Ultrachrome
inks and ImagePrint and you like the strong Dmax (close to 1.8) on
EEM, you will get the same on EVFA.  If you print on PhotoRag, Dmax
drops to around 1.63. I don't know what you get on Epson's Somerset
Velvet, but if it is the same as Somerset Photo Enhanced Velvet,
Dmax is about 1.6.....I have tried this paper.
Ron
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Thomas Fors
<tom@f...> wrote:
> Hi Ron,
Velvet Fine Art?
> Thanks
> --Tom
Over at www.epson.com you can read:
"Artists and photographers require a variety of media surfaces for
their professional work. Epson is proud to introduce its first
cotton paper for the desktop market, Velvet Fine Art Paper. With a
base that is 100% cotton rag, buffered and acid free, this paper is
coated with our popular Enhanced Matte coating, giving exceptional
color gamut and high D-Max."
Over at www.inkjetart.com you can read:
"EPSON Velvet Fine Art Paper - This paper uses the original Somerset
Velvet paper base (from St. Cuthberts Mill), but the coating is
totally different, and this is done by Epson."
I have no way of independently verifying this information....but,
the paper looks and feels like Somerset Photo Enhanced paper and
prints like Epson Enhanced Matte.
Ron
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, sdmey4@a...
tom@f...
> writes:
Epson
is
Enhanced,
an"Epson
resellers claiming
of papers,
the package.
2003-08-31 by Martin Wesley
> From: Mark Hahn [mailto:markhahn2000@yahoo.com]
> Sent: Saturday, August 30, 2003 11:56 AM
> quality etc.).
Mark,
Sorry to hear about your problem. That is a really terrible thing to have
happen to you.
What kind of sleeves were the prints in? Type of plastic that is. Awhile
back there was an issue with the reaction of Somerset Velvet and the release
agents used in some plastic sleeves.
While the optical brighteners will fade an slightly yellow with time it
should take a long exposure to UV light. Had prints been stored with the
open end of the sleeves toward a strong light source?
I am curious as to why this happened to you. I don't use EAM or EEM for
finished prints preferring Photo Rag and German Etching but I do use a lot
of it for proofing and work prints. After 2.5 years I have not experienced
anything like you describe. I wonder if it a paper batch related problem or
something in your particular environment. In any case a change in paper
would seem to be in order.
Martin Wesley
http://www.carolyn.cc/Guests/MartinWesley/pages/MW_01.html
http://www.borderless-photos.de/guests.html
2003-08-31 by flyfishingusa2002
Why believe all that you read? Especially from Epson, have you forgotten the "prints
turning orange"?
Why use a old paper? If  you read here most of the pro's use EEM for proofing and
Hahnemuhle for prints that are sold or displayed. It never ceases to amaze me the
lengths that people go to to try to save a penny when they have spent thousands on
equipement.  In saying that, it looks as if using EEM and the UC inks will work out just
fine if you want to take the risk.
I believed that Injetmall inks and plugin was the way to go...Wrong....I find out that
the inks were crap and now they have dropped the plugin after telling me that you
could see the dots with the Epson driver but you couldn't with their plugin. So why
are they now going to use it?
As I said, don't believe all that you read.
Barry
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "harrisimages" <harris@s...>
> Ron
> tom@f...
> > writes:
> Epson
> is
> Enhanced,
> an"Epson
> resellers claiming
> of papers,
> the package.
I live in a very sunny part of the world! Northern California...I use EEM and have had
no problems with it. but for resell prints I use HPR..
If you read Paul Roake's last post it looks like he agrees with this. But please
remember that we are dicussing paper and not ink sets...
Barry
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "D. Hill" <hill14701@y...>
> Don
> > > People have sent me
> > the look or feel of
> > about it?
> > --Tom
> Do you Yahoo!?
RE: [Digital BW] Hahnemuhle
2003-09-01 by Tim Atherton
it's tucked away in the files section of this very group
> From: D. Hill [mailto:hill14701@...]
> Sent: Sunday, August 31, 2003 11:01 AM
> Subject: [Digital BW] Hahnemuhle
> repackaged papers?
> Don
> Do you Yahoo!?
> Please visit the Group Homepage to check the Files, Bookmarks,
> Polls and other resources as they are often being updated. The page is at:
> If you wish to receive no emails or just a daily digest, or you
> wish to unsubscribe, please edit your Membership preferences by
> visiting this same page.
> - As threads develop, trim off excess portions of earlier
> messages to keep them short.
> - Good manners are required at all time. No personal attacks or flames
> - Before posting a question, search the message archives and the
> various resources on the homepage.
From John Cone's (Inkjetmall/Piezography) recent post on here "RE: [Digital
BW] Re: Septone system (LONG)"
 > FYI, EEM turned yellowish brown rather rapidly (at 100 hours) in our
tests
> and we have abandoned it as an "archival" paper. It may allow
> EPSON inks to
> "test" better, but the paper discoloration is too gross to be
> considered as
> a long-term material. I would appreciate hearing your view on
> that paper in
> that regard and if you have seen that in your test
tests
> EPSON inks to
> considered as
> that paper in
> repackaged papers?
> Don
> Do you Yahoo!?
2003-09-01 by Paul Roark
>on here "RE: [DigitalBW] Re: Septone system (LONG)"
>>in our tests
>> EPSON inks to
>> considered as
>> that paper in
All I see in my testing is what I believe to be rather normal "yellowing" of
the optical brighteners, which is common with all such brightened papers.
EAM/EEM appears "normal" in this regard.
Note that in Jon's post he also observed, "Submitting silver prints to
accelerated light tests usually cracks their surfaces anyway."  This makes
me wonder about the test conditions.  Are his test conditions cracking the
surfaces of silver prints?   I have put silver prints in my tester for short
durations and never seen any surface cracking (also no fading).
Jon is using a Xenon lamp which I believe is very bright.  It may be very
hot also.  With an appropriate daylight filter, it can put out a spectrum
that is similar of daylight -- but that may include UV that is beyond what
my test samples are exposed to.  If the Xenon lamp is being used with no
filter, I'm not sure what the UV content of the light is.
I test with fluorescent light which is probably not as bright or hot, and
probably has a lower UV content.  Wilhelm also tests with fluorescent
lights, and is more careful than most about the temperature of the papers.
So, perhaps some of the differences we are observing result from the test
conditions.  High humidity and high temperature probably accelerate the
acidic reactions.  Perhaps higher UV is also a factor.
I think we all agree now that EEM/EAM is not "archival."  However, it still
has the best image quality per $ as far as I'm concerned.  So, it makes an
excellent and affordable paper for many uses.  It just has a limited life
that may be very limited in extreme conditions.
2003-09-01 by Alessandro Pardi
This is very promising. What inks and workflow are you using with it? By saying that it prints like EEM do you mean that two prints of the same image on the two papers look  exactly the same?
thanks,
Alessandro
<snip>
Ron
2003-09-01 by harrisimages
Alessandro,
Yes, prints on EEM and EVFA are nearly identical.  I am using the
standard Ultrachrome inks on the Epson 2200.  For printing I am
using ImagePrint 5.5 available from www.colorbytesoftware.com. So, I
do all my general printing and proofing on EEM and make my fine art
prints on EVFA.
When printing with ImagePrint, I am using their furnished ICC paper
profiles.
I do find that prints made on EVFA paper using the above method seem
to have more "depth" than when printed on EAM/EEM.
Ron
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Alessandro
> thanks,
> Alessandro
Fade Testing was EAM turns yellow!
2003-09-01 by Martin Wesley
> From: Paul Roark [mailto:paul.roark@verizon.net]
> Sent: Sunday, August 31, 2003 11:43 PM
> Subject: RE: [Digital BW] EAM turns yellow!
(snip earlier)
> "yellowing" of the optical brighteners, which is common with
> all such brightened papers. EAM/EEM appears "normal" in this regard.
> prints to accelerated light tests usually cracks their
> surfaces anyway."  This makes me wonder about the test
> tester for short
> may be very hot also.  With an appropriate daylight filter,
> it can put out a spectrum that is similar of daylight -- but
> that may include UV that is beyond what my test samples are
> exposed to.  If the Xenon lamp is being used with no filter,
(snip earlier)
Paul,
Very true and leads me to point out that one of the possible flaws in
"display life" of "fade" testing is that the test conditions may provide the
activation energy that would not be encountered in real life situations.
Chemical reactions occur at different rates. Some chemical reactions, like
the formation of a latent image on film, require an input of energy to get
things started. This is called activation energy and you can think of it as
the push need to get the ball rolling down hill. For some reactions the
activation energy is high and you have to push the ball over a small or
large hump before it starts to roll on its own.
I am concerned that while very bright light sources are needed to simulate
long years of exposure in testing prints, the high intensity may be
providing the activation energy to trigger reactions that would never occur
except under extraordinary conditions. The good side of this is that
anything that holds up under these torture tests is probably really good
materials to work with. On the other hand they may be giving the false
impression that other materials are inferior when they would actually be
fine under normal conditions. Impossible to say. So we need to continue the
comparative testing but keep referencing it to real world experience as time
goes on.
As to the cracking gelatin two things would have had to happen. One the
gelatin would have had to get very hard and two either the paper or the
gelatin layer dimensionally changed size. Like you I would guess heat but
the high intensity light alone might do it. I have boxes of old family
photos ranging from modern back into the 1880's. Almost all of them have
failed to stand the test of time but none of them show any signs of a
cracked gelatin layer. Even thinking of the faded, sun blasted color prints
in real estate office windows I have not seen this happen in real life.
So this is an excellent example of the fade testing results producing a
"false negative." If we did not know any different, we would be inclined to
rule out silver fiber as a choice for making photographs.
Martin Wesley
