EEM vs. others
2003-09-01 by digikdm
In my experience the Hahnemuhle photorag is closer to EEM than Epson Velvet Fine Art(EVFA) in overall texture and brightness.The Hahnemuhle is also a little heavier and does not ripple at 2880dpi( as does EEM). The Hahnemuhle is only minimally less white, whereas the EVFA is significantly less white.The Dmax appears to be about the same for all three papers from visual inspection alone. By the way, is the Hahnemuhle printable on either side???? If only one side is printable, it's next to impossible to tell which side is the printable surface. For all I know, the few prints I've made on Hahnemuhle could have been made on the wrong side. Given that possibility , even the nonprintable side closely approximates EEM.
