Ferrotype print from digital file?
2003-09-08 by nakalele2
Does anyone know if  there is a service out there that will
produce a ferrotype print from a digital file?  Can't seem to find
anything on the net.   Maybe the two technologies are
incompatible?
  thanks,  doug
Re: Ferrotype print from digital file?
2003-09-08 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "nakalele2"
<floydd001@h...> wrote:
A ferrotype print? As in producing a high gloss finish on glossy
fiber-based paper? Or has the name been appropriated by some
alternative process? Please define!
Steve Karafyllakis
www.stevekphoto.com
> incompatible?
>   thanks,  doug
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
"nakalele2"
some
Sorry, I didn't know this term was used in different ways.
  I am trying to get an "old school" tin type print on a sheet of
metal made from a digital file.
  thanks for any and all help,  doug
> "nakalele2"
> some
Right! So you're looking to reproduce the Daguerrotype or tintype
effect from a digital file? whew!  Let's see... forget having it
done, its almost certainly a do-it-yourselfer. I can think of 3
approaches that might work. The first is to buy a tintype kit from
(I think) Freestyle photo, or maybe Calumet? someone still sells
them. The kit is basically a few pieces of emulsion-coated tin which
you expose and process in a wet darkroom with a negative made from
your file by a service bureau. 2nd: Find some suitable pieces of tin
or aluminum (nothing ferrous) and hand coat it with Liquid Light
emulsion, then expose and process in wet darkroom, again with neg
from dig file.  3rd possibility: Print your image on the type of
film that's intended to go on T-shirts, or overhead transparency
film, or some flavor of back-laminating film, and laminate it to the
tin sheets instead. Option 3 would be the easieast by far, but would
probably yield the least convincing results. If you have a darkroom
available, buying the kit would be the easiest, and you could
probably make a neg by printing your (reversed)image on overhead
transparency film in an inkjet printer. None of these methods are
what you'd call quick'n'easy though, maybe some other list member
can come up with easier alternatives?
Best Luck,
Steve Karafyllakis
RE: [Digital BW] Re: Ferrotype print from digital file?
2003-09-08 by Loris Medici
The only ferrotype I know is the alt. process one (also named tintype).
If there's another ferrotype process please explain; I would like to
learn about it. BTW, many alt. process artists use digital files
nowadays (by the means of using (a) inkjet / (b)imagesetter negatives on
(a)transparency media / (b)lith film).
> From: Steven Karafyllakis [mailto:steve@...]
> Sent: Monday, September 08, 2003 4:37 AM
> Subject: [Digital BW] Re: Ferrotype print from digital file?
> Steve Karafyllakis
www.stevekphoto.com
> incompatible?
>   thanks,  doug
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Loris Medici"
tintype).
to
> learn about it.
What I was referring to isn't an entire process, just a finish for
fiber-based glossy paper: you soaked the print in a glazing
solution, and then dried it emulsion-down on a drum dryer to produce
a mirror-gloss finish. Very popular in the 1950's and '60s for
commercial work, but it was always finicky; it became obsolete in a
hurry when RC paper improved enough in the mid-late seventies.
Perhaps the name was appropriated from an obsolete (and recently
revived) alt. process?
2003-09-08 by Robbe
I still have a couple of clients that insist on ferrotyped glossy
prints.  I don't know the current requirements, but 5 or 6 years ago,
the national historical archive was still requiring them -NO RC prints
would be accepted nor would they accept air-dried fiber glossy paper.
And I don't use a glazing solution. Water works fine if the plates are
clean and polished.
Hmm, I wonder if you took a piece of fiber F paper, fixed it, air dried
it, printed an image w/ultrachrome ink(sorta waterproof) and then
ferrotyped it?
Robbe Gibson
www.robbepp.com
714-637-3288
Sent: Monday, September 08, 2003 7:20 AM
tintype).
to
> learn about it.
Re: [Digital BW] Re: Ferrotype print from digital file?
2003-09-09 by Carolyn Frayn
> prints.
Like another poster, I thought ferrotype was done with a collodian
process also called tintype, so when you typed ferrotyped... with the
"d" I did a search of that word, here's a little definition that seems
to clear things in my head anyway.
   F E R R O T Y P E D
Ferrotyped: refers to the procedure for producing a glossy or glazed
surface on a photographic print by drying it with the emulsion in
contact with a highly polished surface.
The term " ferrotype " reflects the fact that the original surfaces
used in this process were plates of enameled sheet iron. Today those
surfaces are chrome - plated, stainless steel, glass, or plastic.
In order to be successfully ferrotyped, the photographic print has be
fixed in a fresh hardening fixer, thoroughly washed, and squeegeed
image - down onto an immaculate surface. The print is then exposed to
heat. It is common in this process for the surface to be unevenly
glossy, bubbled, or ridged, due to air pockets between the print and
the drying surface and fluctuations in temperature at the drying stage
Carolyn
2003-09-09 by mfaphoto@optonline.net
When I was learning photography back in the 1960's, I used to squeegee the prints that I wanted glossy onto ferrotype plates. The ones that I used were the steel ones with a baked on black enamel coating. The plate had to be  polished with a special plate polish that would allow the print to peel off as it dried. If it wasn't "polished" it could stick and be almost impossible to remove. However, a soaking in Pakosol solution before squeegeeing helped a lot. Sure there were tricks to it, but it wasn't that complicated. You got the hang of it after a couple of times and if you screwed up, you just resoaked the prints and tried again.
Gee. Am I old or what?
Russ
2003-09-09 by Martin Wesley
* -----Original Message-----
* Sent: Monday, September 08, 2003 11:31 AM
* To: DigitalBlackandWhiteThePrint@yahoogroups.com
* Subject: RE: [Digital BW] Re: Ferrotype print from digital file?
* I still have a couple of clients that insist on ferrotyped
* glossy prints.  I don't know the current requirements, but 5
* or 6 years ago, the national historical archive was still
* requiring them -NO RC prints would be accepted nor would they
* accept air-dried fiber glossy paper.
* And I don't use a glazing solution. Water works fine if the
* plates are clean and polished.
* Hmm, I wonder if you took a piece of fiber F paper, fixed it,
* air dried it, printed an image w/ultrachrome ink(sorta
* waterproof) and then ferrotyped it?
Robbe,
People have tried printing with inkjet on processed silver gelatin paper and
I am afraid it does not work. The fixing process hardens the gelatin. The
ink just sits on top it and is easily wiped off. Inkjet pretty much requires
special receptor coatings to control the absorption of the ink into the
paper.
Even if the ink did stick it would be on top of the paper and look nothing
like a ferrotyped print.
To clear up the confusion. "ferrotype" has two definitions:
"ferrotype
-v., -typed, -typ.ing,
-n. Photog.
-v.t.
to put a glossy surface on (a print) by pressing, while wet, on a metal
sheet (fer'rotype tin").
-n.
1. Also called tintype. a positive photograph made on a sensitized sheet of
enameled iron or tin.
2. the process of making such photographs."
I guess the original "ferrotyping" of silver fiber prints was done by
pressing the prints face down on the same smooth metal sheets as used to
make "ferrotypes".
Martin Wesley http://www.carolyn.cc/Guests/MartinWesley/pages/MW_01.html
http://www.borderless-photos.de/guests.html
2003-09-11 by Dennis W. Manasco
At 7:47 pm -0600 9/8/03, Carolyn Frayn wrote:
%< snip >%
>contact with a highly polished surface. The term " ferrotype "
>reflects the fact that the original surfaces used in this process
>were plates of enameled sheet iron. Today those surfaces are chrome
>- plated, stainless steel, glass, or plastic. In order to be
>successfully ferrotyped, the photographic print has be fixed in a
>fresh hardening fixer, thoroughly washed, and squeegeed image - down
>onto an immaculate surface. The print is then exposed to heat. It is
>common in this process for the surface to be unevenly glossy,
>bubbled, or ridged, due to air pockets between the print and the
I have to disagree with parts of this definition. I know that there
are a lot of different types of ferrotype machines and that not all
of them give optimal results without great care and preparation, but
not all of them require squeegeeing. And some (at _least_) of them
have a low probability of causing "unevenly glossy, bubbled, or
ridged" prints.
In the mid 70's at R.I.T. we used large cylindrical-drum ferrotype
machines. They had big chromed-steel drums (maybe a yard or more in
diameter) and used wide canvas belts (probably 24" to 36") to feed
prints onto and around the drums. The tightly-stretched continuous
belt fed onto and around about 75% of the drum and then around some
other rollers which brought it back to the staging area. There were
also some smaller models that looked to be about 3/4 scale versions
of the same thing. There was a temperature setting for the drum,
which was usually set to "Burn Fingers but Don't Ignite Paper," and a
speed setting. If the speed setting was fairly low you could place
quite a few prints in a space-saving manner along and across the belt
and have your whole job arrive within a minute or two of the first
print.
You just placed your prints on the canvas feed area and popped them
off when they came around the far side of the drum (they usually just
dropped, but second passes around the drum were...not recommended,
though not usually fatal). I sent hundreds of prints through those
machines and I never squeegeed. I don't remember anyone else doing so
either. I never had any problem with uneven glossiness, bubbling or
ridging. I suspect that (with these machines) squeegeeing might well
have _caused_ "uneven glossiness," etc.
You did have to use a hardening fixer and pay enough attention to the
process that you didn't lay your print on the seam that completed the
belt. You also had to stay away from the last quarter of an inch or
so of the edge of the drum: there was a small area at each side that
wasn't chromed and was recessed about a 64th of an inch.
If my print was good before I sent it through the ferrotype machine I
always got back perfectly good "pressed" prints when I peeled them
off the drum.
Sending RC prints through the machines was usually "not recommended"
and, depending on the temperature setting, might require additional
"remediation" on the part of the student. (Though I think that low
temperature settings and fast speeds were successfully used by some
-- with good results.)
-=-Dennis
