Re: [Digital BW] Specific Zone Placement
2003-09-10 by Thomas Fors
Don, I think the technique is good, but I would recommend taking it a bit further and finding out: 1) How many zones can you record in a single exposure. 2) At what zone does your camera overexpose and blow out the highlight detail. You may find that your camera's exposure range only covers 5 zones or so. Knowing your ISO to get midtones placed correctly is good, but I think knowing how to place highlights without blowing them out is much more useful for digital captures. Of course with most digital cameras you can always check the histogram after the shot. It would be nice if the built-in metering took into account all pixels and fit every scene into the dynamic range of the camera for each shot. Maybe some day... --Tom
On Wed, 10 Sep 2003, D. Hill wrote: > > I've had a few responses about my method of > determining effective ISO for the digital realm - so > here goes: > > This testing is very similar to that done with > conventional photographic materials. I use a > hand-held meter, even toned card (white or grey), and > a zone dial (the sticker from calumet that attaches to > the pentax spotmeters). > > To determine effective ISO of the camera, read your > cameras manual for the default ISO setting, and set > your camera as such. Most digital cameras default at > 100, but still check. > > Use a tripod and fill the viewfinder with the white > card - I typically will make sure that the light is > even across the card, and the sun is at a 45 degree > angle to the card itself. At this point, set the > focus at infinity. > > Meter the card, and do a series of Zone V exposures. > I shoot a series in 1/3 increments from 1 stop below > to one stop over ASA 100. This gives me a set of > seven Zone V values from ASA 50 - 200. > > At this point, I convert all images to 16 bit > greyscale files in photoshop as stated in my previous > post. Using the eyedropper tool, I choose the image > that is closest in value to 50% (zone V value). > > If you have taken notes, you should be able to line up > what image is the correct ISO for your equipment. My > equipment sets my ISO as 80 - but most likely your > results will vary from mine. > > This is a very simple and quick method in determining > ISO - and is extremely helpful when you want to place > a specific zone for imaging. As I stated before, this > does not allow for any processing functions of the > zone system (such as n-1, n+2, etc.) but does allow > specific placement of the important values. > > Good luck, > Don >
