Adjusting VM curves and squealing
2003-09-10 by Matt Betea
During the workflow for VM printing, it's wrong to use curves to
adjust the tonal range of the image, then apply the PR tone curve?
The right way would be to apply a PR tone curve, then using that
curve make adjustments there? (I apologize as I can be thick-headed
sometimes<g>) The past few images I've been trying it the latter and
I'm not quite there yet, but I'm closer than I ever was.
I had another question not regarding the VM curves, but my 1280
printer. It gives out a high pitch squeal as it's printing. I'm kind
of thinking it's something to do with the rod that the heads slide
on. My question was what would be a good lubricant to use on the rod
(no pun intended) to see if that does fix it? I appreciate any help
about these questions. Thank you all so much.
matt
RE: [Digital BW] Adjusting VM curves and squealing
2003-09-10 by Ed Mathews
> From: Matt Betea [mailto:mbetea@...]
My understanding is that all adjustments to the image should be made
prior to applying the Roark curves.  I make all my adjustments, then
save the image, then apply sharpening and the Roark curve and print it.
When done, I always put the image away without saving the sharpening or
Roark curve.  Seems to work for me.
Ed
http://lightandsilver.com
Re: [Digital BW] Adjusting VM curves and squealing
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ed Mathews"
it.
sharpening or
Hmm, looks like it's back to the drawing board. No matter what I do
if I make adjustments prior to applying the Roark curves I get
posterization. And the histogram still reflects a good amount of data
still (it doesn't look jaggy or like a comb at all). Now without
adjusting anything, applying the Roark curve then using that for
adjustments doesn't give me any posterization, but then the images
don't have the contrast I would like.
Appreciate the help Ed, I guess though no one else has ever had this
problem. Thanks.
matt
<snip>
> posterization.
You are certainly not the first to encounter this.  I had a heck of time
with it with my old 1280, with all of Paul's curves.  Others have
reported this as well.  I ended up using another set of curves which
worked pretty well for me (the Tyler curves).  But with all the same
exact computer equipment (except the new replacement 1280), I now get
excellent results with the MW curve.  Luckily, I like the tone of that
curve the best, and really don't desire much else, because I still get
it to some degree with the others.  Paul suggests I move to the UT B&W
inkset, but I'm happy with what I'm getting now and a little leery of
the clogs I've heard reported here with the new inks.  I might wait a
little.
I've actually never bothered to look at the histogram after applying the
curve.  I probably shouldn't at this point because I like what I'm
getting and I might be scared if I do!  But have you considered bumping
up the contrast in the printer dialog box by using the sliders?  My
normal setting for my tastes requires +10 in the contrast slider.  I
adjust the image so the contrast is good on my screen, but the prints
are indeed a little flat from there if I print without further
adjustment.  So rather than blow out the highlights and shadows on the
image itself, I adjust the contrast from that point with the sliders in
the print dialog box.  Plus 10 is my default, and 90% of my prints look
good that way.  At that setting, my stepwedge shows excellent
smoothness, and great separation of tones throughout almost all the
percentages.  My 0% to 5% even shows great separation, at the expense of
a little lack at the bottom end, where 95% is about pure black.  But
that doesn't bother me, because I like the look and have never really
needed to see all the detail in the darkest of shadow areas anyway.  I
always printed in the darkroom like that too.
Ed
Re: Adjusting VM curves and squealing
2003-09-12 by Matt Betea
time
get
that
get
B&W
of
a
> little.
applying the
bumping
prints
sliders in
look
expense of
really
anyway.  I
I'll keep trying, thanks for the help. Guess I should start using the
title "What printer for MIS b&w inks?" Maybe I'll get some more
responses as those seem to be popular threads. Thanks.
