Re: [Digital BW] Nikon Coolscan 800 120 film holder
2003-09-11 by Ernst Dinkla
From: "nick90290" <NickBrandt@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Thursday, September 11, 2003 9:13 PM Subject: [Digital BW] Nikon Coolscan 800 120 film holder > I just bought a Nikon Coolscan 8000 yesterday, and am getting very good > scans from the outset, it seems, The only problem is the 120 format film > holder. > > Aside from the fact the clips holding the negative in place seem to treat the > negative very roughly in the way they clip hard into the neg edges, my biggest > problem is I that the scanner does not scan quite the full width of the negative > (and therefore edge/rebate as well) in the scan. It's cropping the last albeit > small part of the actual image on the left side of the image. > > Am I missing something here? Is there some way to increase the dimensions/ > proportions of the area to be scanned somewhere? I tried placing the chosen > neg in the middle of the holder but the scanner still read the image with the > same cropping. > > Oh, and also, my zoom buttons in preview won't work, They're grey, and so > inoperative. > > Any solutions/explanations much appreciated. > > Thanks > > Nick The Nikon 8000 scans up to 83-4 mm length and 56 mm width and with the rotatable glass holder even a bit wider I believe. So it will not scan the 88 mm of a Voigtlander Bessa but it will scan the 83 mm of a Kodak Monitor to mention a few old folders. Sometimes it is easier to use the 6x7 setting for 6x6 frames. If you have to scan negatives you better get Vuescan or Silverfast as the scanning software because Nikonscan has a habit of clipping the neg shadows. And Nikon hasn't done anything in more than a year after a list with users that complained about that has been sent to them. Ernst
