Amsterdam, Epson 4000 printer introduced
2003-09-17 by Ernst Dinkla
A good friend did send me a scan from a magazine article in Dutch on the introduction of the Epson 4000. Short translation: As expected an 8 ink printer size up to A2. What some will see as a replacement for the 3000 but in the article it is called a replacement for the 5000. Could be both of course. Software change between matte black and gloss black. Borderless printing up to 48 cm / 19", roll and sheet. Maximum speed with 8 colour mode 1 minute for A2, in CMYKCMYK mode 0,6 minutes. Up to 1.5 mm thickness of substrates. Monochrome prints variable in neutral, warm, cold, sepia. Maximum cartridge size 220 ml. Ink use is software controlled like in the 7600 etc. Waste container like the 7600. 3 versions of the printer: Stylus PRO 4000-C8 is the 8 colour version for photographers, artists, design studios. Stylus PRO 4000-4C is the 2x CMYK version for 3D-CAD, industrial design, GIS and POP display. The Stylus PRO 4000-PS is the PostScript version for proofprinting. 3,5 picolitre minimum droplet size. Some talk about meniscus-control that I interprete as surface tension control to keep blleding low and the dotshape correct. Maximum resolution of 2880 dpi. Ultrachrome ink. 70 to 75 years fade resistance a la Wilhelm. There's a picture on the page, in short a modern version (7600 style) of the 5000 but of course wider and with 4 carts at each side. So no twin bag carts. Ernst, in cooperation with Bernard
