Sepia Tone on a 7600/9600
2003-09-24 by jmoore172002
For those who do not have ImagePrint, I have--through a little trial and error--come up with a method that gives me a nice, warm, sepia toned print on Photo Rag using UltraChrome (with the Photo Black). The result is pleasing to me, and I think is a good solution for those unable or unwilling to spend major bucks on ImagePrint. (By the way, I do use ImagePrint myself.) This method uses the standard Epson 7600/9600 driver along with Bill Atkinson's profiles, which, as most of you are aware, can be downloaded for free from either Bill's website or the Epson site. On this particular method, the following Bill Atkinson profile is used: 9600 SmFineArt SFA1 Std. v2.ICC. Here are the steps: If your image is in grayscale, convert it to RGB, 8-bit, and create a Curves adjustment layer. When you create an adjustment curve on an RGB file, you have four possible curves available: RGB, R-channel, G-channel, B-channel. Make the following changes to the curve: RGB: no change; R channel: input=119, output=128; G-channel: no change; B channel: input=128, output=119. (You can, of course, increase or decrease the intensity of the sepia tone by moving these numbers around; small numerical changes result in fairly substantial changes in tone. Experiment!) Print the image using the Atkinson profile. It is very important to make all the driver settings exactly as suggested by BA for this particular profile. Once again, this method gives me a sepia tone print that I am happy with. I have used it on different type photographs from landscape to studio portraiture, and it gives a pretty neutral sepia tone without metamerism. Give it a try and experiment around with different settings on the curve. This is for Hahnemuhle Photo Rag paper. On other papers, such as EEM, the results are VERY different. A different curve would be necessary. My paper of choice is Photo Rag, and that is what this curve is for. One final note: For those who have never attempted to create their own profiles, the process requires a tremendous amount of time and work. That Bill Atkinson makes these profiles available for free is an act of supreme generostiy on his part. In the past, I have paid as much as $200 for just one profile that is not as good as those BA provides for free. Just one person's appreciation.
