Changing brightness of final print. How?
2003-10-08 by flabes23
HI!
What's the best way to brighten up a print with the MIS VM-inks and
the roark-curves? I've scanned loads of pictures without having
properly calibrated my monitor and they all print out a bit too
dark. So I want to brighten them up without changing the file. The
two possible ways I can think of are 1) raising the curve in PS
after applying the roark-curves, 2) changing something in the
printer settings, so that only the final print is affected, not the
file itself. So, what do you think? Which method is best? Are there
any others (perhaps with Qimage, which I also use)?
Peter
Re: Changing brightness of final print. How?
2003-10-08 by Stephen Kobrin
Peter,
This may be an overly simple answer to your question, but if your
prints are consistently dark, why not just cut the brightness of your
monitor using your video card control?  I have separate monitor
settings for B&W and color prints (my video card software allows
reasonably fine steps up and down) and even without a lot of fine
tuning, my prints generally come close to what I see on the screen.
When I want to adjust the brightness of the print, I add an
adjustment layer just before applying the Roark curves.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "flabes23"
<peter.bongard@t...> wrote:
> HI!
> Thanks,
> Peter
2003-10-08 by Nicholas Hartmann
If your printer driver allows them (which I believe most Epson drivers do),
you could try applying a Transfer Function, which does not affect the image
file but does influence how the printer interprets that file. The Transfer
Function is simply an adjustment curve; look for the selection field in the
Page Setup dialog box. You can create and adjust as many curves as you
like, then save them and Load them for individual images.
-- Nick
NICHOLAS HARTMANN
Technical and scientific translator
(414) 271-4890
nh@...
http://www.nhartmann.com
2003-10-09 by Steven Karafyllakis
A couple other alternatives: If you have converted to 8-bit, a
curves adjustment layer works just fine. I forget if you're better
of putting it on top of the RGB partitioning curves or under- one
way affects the function of the RGB curves, the other way does not.
Another alternative that has some repeatability if you're working in
16-bit and can't use layers (yet-I can't wait for PS 8.0) is the
following: open the curves dialogue box, make your adjustment & save
the curve, but DON'T save the file with the adjustment applied, just
use it to print, & closed with out saving. When you want to reprint,
open the curves box again, & load the saved curve.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Nicholas
and
there
drivers do),
the image
Transfer
field in the
you
> -- Nick
> NICHOLAS HARTMANN
> (414) 271-4890
> nh@n...
