Re: [Digital BW] Septones Question was RE:Moab Entrada paper
2003-10-11 by kenschuster
Martin - After the initial "missing Septone dialog window" conundrum, which was solved by putting the dongle in a different USB port, I was unable to get even close to a perfect nozzle check. After the printer rested about 12 hours, two of the inks were still missing a few lines, but the others were fine... more cleanings resulted in identical nozzle check prints, so I gave up and made some test prints. I was used to keeping the print head height adjustment at "envelope" (high) because of the Hahnemuhle Photo Rag 308 paper that had become my favorite in rolls and sheets, and using the roll and manual rear loading. That's what I used for the first couple of Entrada Fine Art 190 tests. Since the 190 is thinner than the 308, I wanted to see if there'd be a difference using the low position, and figured I might as well load the paper in the "sheet" feed. The first sheet came through fine, and I didn't see any difference, but one of the nozzles must have contacted the paper surface of the second test, resulting in ink blobs that were dragged across the paper. Luckily, it didn't leave a mess inside the printer. A ran a few sheets of plain paper through it to pick up ink that was tracked onto the "pizza wheels." The third sheet was clean. I ran a nozzle check and... ta-da! Perfect! Ran another and it was perfect too. I don't know if the blob episode had any relation to the bad nozzle checks, but every nozzle check since then has been perfect. Print quality... My monitor image in Photoshop is a bit higher contrast than the print... easy enough to correct. Tonal transitions are smooth. I've been experimenting with the color sliders for highlights, midtones and shadows, and am favoring about 15% warmer highlights, 7% warmer midtones and keeping shadows at 100%. Moving warmer appears to pick up some magenta in daylight, but not noticeable in tungsten and fluorescent. The Entrada Fine Art is as white as Hahnemuhle Structure (which I like very much, but I understand distribution will be discontinued in the US), and quite a bit whiter than Photo Rag. Early-on, I tried one test on Photo Rag, and the awful green cast was more than I wanted to deal with at the time. I'm planning on trying it again today. Hopefully, I'll be able to zero-out the color cast, and then I want to see if I can get a higher Dmax than the Entrada. I have a feeling the Entrada blacks are as black as I can get on matt paper. (I love not seeing reflections, but I really miss the shadow details all the way down to BLACK I used to get on the old Seagull paper, and selenium toned Gallerie, in the d-d-darkroom.) Specular highlights are paper white, and there's good highlight detail. All in all, I'm happy with Septones. Now, I'm surrounded by spectacular fall foliage, here in the New Hampshire mountains, and I'm itching to print color again. I'm anticipating reading reviews of the Epson 4000 that's rumored to be available in January. _____________________________________________ Help end spam and telemarketing... never respond to it, even to "unsubscribe." [Non-text portions of this message have been removed]
