QTR Linux install question
2003-10-13 by David Wroblewski
For those of you who have installed QTR on Linux, does this problem
sound familiar:
I have compiled and installed the software, defined a QTR version of
my 2200 as a printer, and installed the example curves. Running a print
job via "qtcups CurveDesign/Images/qtrip-big.jpg"
produces a print dialog with all the right stuff, ie shows the curves
and options as expected. When I click OK the print manager shows a
document getting queued for the printer. So far, so good.
Then the job disappears off the printer queue but nothing happens with
the printer. (As a sanity check, if I invoke qtcups as above but print
though the standard, non-QTR, printer definition the image prints
immediately without problems.)
When I look at the the results of Print-Gimp-ErrorLog.command, I see two
suspicious things. On jobs where I select paper source = standard, I see
warnings that say "Media Tray Empty!" and "Invalid Printer settings!".
If I select paper source as "Auto", I see those messages plus
"PID 1234 crashed on signal 11!"
Thanks for your patience. Resolution will get rolled into the Linux
installation notes, of course.
David
Re: QTR Linux install question
2003-10-14 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David Wroblewski"
> sound familiar:
> Thanks,
> David
Hi David,
The error message "crashed on signal 11" basically means the program
went off into never-never land.  The PID (process id number) should
reference which program crashed -- is there a message about starting
a process with that PID in the log?  i.e. what program is being run there?
Also are the other messages preceded by some indication of what
program is finding these errors?
You might also try some other file formats like a tif file.  Make sure
its a grayscale, 8bit file and that you select the QTR mode.  You can
also try printing without a curve -- it ought to print thru gimp-print
in the normal mode.
Roy
2003-10-14 by David Wroblewski
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy
Wroblewski"
Roy, I've emailed you a bit of a cups error log file that illustrates
what's happening, with some notes and answers to your questions...
-David
program
starting
run there?
sure
can
print
> in the normal mode.
> Roy
David,
I got your log file and I'm answering here since maybe some of the Linux
folks might have some comments.
From the log file, the program which is dying is "imagetoraster".  This is
a CUPS filter that converts several image formats to the raster format
needed by both QTR and Gimp-print.   On the Mac this program is no
longer used, its basically been superceded by ghostscript which also
can deal with postscript data.
So on the Mac, Ghostcript is required for gimp-print and therefore QTR.
I suspect its a matter of getting ghostscript installed to make this
all work.
Roy
> Wroblewski"
> -David
> program
> starting
> run there?
> sure
> can
> print
> > in the normal mode.
> > Roy
Thanks Roy, that's very useful.
I certainly have ghostscript installed, it comes with Redhat 9.
rpm -q ghostscript returns "ghostscript-7-05.32.1", to be exact.
If I understand you, we'd like to see /usr/bin/ghostscript being
invoked (with some set of options, I'm sure) during CUPS
processing in place of imagetoraster.
Hmmmm... How to change this.... Wild guess, I grepped for
imagetoraster in /etc/cups and I see that there are many
references to imagetoraster in /etc/cups/mime.convs for
starters... what does the image/jpeg entry in that file
look like on the Mac?
-david
> David,
Linux
This is
format
also
QTR.
this
> all work.
> Roy
Wroblewski"
> > Wroblewski"
illustrates
questions...
> > -David
> > program
should
> > starting
being
> > run there?
Make
> > sure
You
> > can
gimp-
> > print
> > > in the normal mode.
> > > Roy
