Re: [Digital BW] Re: MIS FS Sludge
2003-10-15 by Barry Kelsall
Two years is the shelf life of these pigment inks. I would replace the ink, the lines & the carts at this point. You will probably find your new ink has expiration dates on it. Rick at MIS once told me that there is a bacteria that causes the sludge, so it is important to start over clean! -BK ----- Original Message -----
From: "londuck" <lon_c@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Tuesday, October 14, 2003 9:47 PM Subject: [Digital BW] Re: MIS FS Sludge > Regarding my CIS-MIS FS Quadtone Sludge Problem > > First, thank all of those on the list that help with my sludge > problem. > > I have the printer working again. There was a very nasty plugged up > black (K) line in the CIS. With the lines disassembled very > aggressive vacuum and pressure would not clear the black (K) line. I > finally had to resort to a steel wire in the tube. > > It was a grand mess. I will be repainting part of my wall and > ceiling. > > I did not replace the black cartridge on the CIS yet, but I when I > reassembled everything and drew the vacuum to get the black cartridge > primed, it seemed sluggish. Even though the printer seems to be > working fine, I think I will replace the black cartridge soon. > > I had used the printer for about two year without a problem. > Although I cleaned out all of the lines, it seemed that there was > only a problem with the black. Possibly routine maintenance at a > year on only the black might be a reasonable approach, and a longer > time for the other tones. > > One list member asked if it was worth it (1160 / CIS / MIS FS > Quadtones); I am not sure. One you are in deep water you typically > loose your objectivity. > > One comment I can make. If you are not very mechanically inclined, > run away. This is not turnkey functionality. > > Enjoy! Lon
