CFS question - Vacuum Question!!! (I've read all the FAQ's)
2003-10-16 by freegrad
I'm wondering if you need to maintain the vacuum in the tubing lines
after filling the CFS carts (after the ink 'surges' to the carts and
the ink tube is 'at least 1" in the bottle'). I understand that I
let the sponges soak up the ink overnight, but then I'm instructed
to put the caps (with the tube and vent holes) on the bottles... Am
I supposed to somehow maintain the vacuum while:
1. pulling the tube out of the bottle,
2. capping the bottle with the drilled cap,
3. cutting the excess slack out of the lines,
4. marking the tubes at 3 3/4", and
5. inserting the tubes through the caps and into the bottles?
If so, how? I've read everything I could find and it's probably so
obvious that no one felt it meritted mention. I called tech support,
but I wanted to get started tonight (printing tommorrow!!! =)
details: 1160 MIS CFS with UT inks
Thank you so much for your help - this will be my first (hopefully)
working CFS...
Jim Batzer
dbatzer@...
Re: CFS question - Vacuum Question!!! (I've read all the FAQ's)
2003-10-17 by Jeff Randall
Once you've filled the carts the vacuum is gone replaced by the
ink.  So don't worry about the ink-bottle ends of the tubes.  Try to
minimize the loss of ink from the tube as you struggle to get them
stuck through the bottlecaps and cut off to the proper length.
Any bubbles in the lines from the bottles will be drawn with the ink
into the carts.
I usually insert the tubing into the bottle tops and cut everything
to approximate length (making sure the bottles are in the correct
positions and there is extra tubing length) before I load ink into
the carts and then do a final adjustment.  A whole lot less messy.
I currently have CFS systems on a 1160 and two 1270's.
Hope this helps and is not too late.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "freegrad"
<jbatzer2@a...> wrote:
> Hi,
lines
and
support,
> working CFS...
> Jim Batzer
> dbatzer@c...
