Re: [Digital BW] Re: New CFS 1160 UT question (pre-vacuumed carts?)...
2003-10-18 by Barry Kelsall
Optimally the carts should contain 10-20% air in any CIS/CFS, so the air in
the lines is no problem. More commonly, the problem is not enough air in the
carts, which can cause bleeding on the paper, or siphoning of ink away from
the heads, & more...  I am now a convert to the bottom-fill method, in which
you can measure the amount of ink that goes in the cart precisely. -BK
Sent: Saturday, October 18, 2003 6:36 AM
Subject: [Digital BW] Re: New CFS 1160 UT question (pre-vacuumed carts?)...
> Thanks Jeff,
> Is this the case even if there's no ink in the tubing? The ink will
> be pulled in and there shouldn't be problems with air bubbles?
> Thanks again,
> Jim Batzer
2003-10-18 by Jeff Randall
Jim:
I'm not sure about the optimal percentage of air in the carts, but
as Barry says some air is necessary to stop back syphoning or excess
ink bleeding through the head onto the paper.  The vacuum fill
method is not 100% efficient (can't achieve a perfect vacuum),
therefore it always will leave some air in the carts. The amount of
air left by the vacuum fill method has worked for me through 4
installations.
The real problems begin when there is an air leak into the cart
either at the fittings on top or the ports on the bottom. The drawn
in air replaces the ink that would have been drawn in and ultimately
you get an ink starvation problem and/or an ink clot caused by the
solvents in the ink diffusing into the enlarged air pocket.
Diffusion of solvents (water, glycols, alcohols, etal.) through the
plastic ink delivery tubes leaving a clot is also a problem,
especially in a dry and hot atmosphere.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Barry Kelsall"
the air in
air in the
away from
method, in which
precisely. -BK
> From: "Jim Batzer" <jbatzer2@a...>
carts?)...
> > Thanks Jeff,
will
> > Thanks again,
> > Jim Batzer
2003-10-19 by Bob Frost
Barry,
If you fill cartridges from the bottom, through the exit hole, surely all
the grot in the ink is going to end up on the wrong side of the filter in
the cartridge, and you are then going to rely solely on the very small
filter in the print head to stop that grot from clogging your nozzles? I'm
just beginning to experiment with refilling cartridges (1290 and 2100) and
although I can see some advantages of filling from the bottom, the filter
problem puts me off.
Bob Frost.
2003-10-20 by Barry Kelsall
Bob,
All of the carts (and there are several) I have filled with the bottom-fill
method have been problem-free (and that includes clog-free). I cannot say
the same for the vaccuum method. I am convinced. Perhaps the good ink I use
from MIS is relatively grotless. You are free to go your own way, I am just
trying to help by reporting my experience, which is perhaps above average
due to the battery of printers I use. -BK
Sent: Sunday, October 19, 2003 1:28 PM
Subject: Re: [Digital BW] Re: New CFS 1160 UT question (pre-vacuumed
carts?)...
> Barry,
> Bob Frost.
> From: "Barry Kelsall" <bktimes@...>
