RE: optimum resolution for inkjet prints
2003-10-20 by Joseph Erbacher
It seems that it would be better to try your test at 180, 360, 540 and 720 for Epson printers. -Message: 1 Date: Sat, 18 Oct 2003 13:08:41 -0000
From: "J Michael Sullivan" <michael@...> Subject: Re: Optimum resolution for inkjets Do the following test: take a sharply-focussed, highly-detailed, but *UNSHARPENED* (this is important) image of yours at 600 dpi (or more accurately 600 "spi": samples per inch) and print it at 8"x10" @ 1440dpi then downsample it to 400 spi and print that then downsample it to 200 spi and print that and tell me if you see any difference. (I just did this myself, btw). Most people can readily see a difference with the 200 spi image, but can't see any significant difference between 400 and 600 (at least not at 1440 dpi output). All things being equal, epson uses a custom stochastic dithering algorithm that is likely based on "something" in the neighborhood of 360dpi as its base from which to derive the dither. Send any more than that to the printer and the data is certainly DOWNSAMPLED by the printer. The test above more or less proves this. Stick with something in the neighborhood of 360 spi and you can't go wrong.
