Re: QTR: hitch in the greyscale ramp for EEM_2200-cool?
2003-10-20 by Peter Miles
Roy Harrington Wrote Message: 14 Date: Fri, 17 Oct 2003 18:03:30 -0000 <major snip> .... If you interested in the gory details of this I'd be glad to share it offline. Roy <end snip> Hi Roy and David I have been following your thread with a lot of interest. I would like you to continue this discussion on the Digital B&W list. I'm just starting wrapping my head around getting the best out of roy's QTR and find your discussion very useful. Much thanks Peter Miles
2003-10-20 by David Wroblewski
Peter, There's not more to hear at this point. I'm spending time printing on my 2200 through QTR using the Epson UltraChrome inks getting to understand what I can expect from this setup. The output is so close to metamerism-free and dotless on EEM paper that I'm thrilled. (It looks like it warms very slightly under incandescent lighting, and I need a loupe to see the dots at 5%.) I can mix a warm and cool curve and get pretty much any range of tone I care about. I haven't felt the need to take advantage of Roy's offer to share the gory details of calculating dot size transition points. From a user's point of view, that's truly esoterica. What I've got works fine, once I changed one constant in the QTR code and recompiled. Next for me will probably be getting a set of UltraTone carts from MIS. I'd like to understand what difference a set of real quad inks make, though I'm a little nervous about switching inks--listening to the discussion so far, I can't get a definitive reading from the group on the risk of a bad (i.e. clog-inducing) interaction between the residual UltraChrome in the pipes and on the parking pads and the Ultratone inks... in a 2200, not a 1280. So that's where things stand for me. I'm very happy with QTR. It's not a shrink-wrap solution, it requires some learning on the part of the user, but that's good for me. I like that. I understand more about B&W printing because my hands are a little dirty. Going through the calibration exercises alone taught me things I didn't know. There is a level of precision available to me now that I had no way of getting to when I was printing directly from photoshop through the Epson driver. The active part of my learning curve right now is bulletproofing the printing process from Linux so I don't screw up (like I did this weekend) and print a tif file with an alpha channel and wind up with an all-black print. And getting the centering of images to come out correctly. And making sure the output matches my screen. Etc. -David --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Peter Miles <P.Miles@m...> wrote: > Roy Harrington Wrote > Message: 14 > Date: Fri, 17 Oct 2003 18:03:30 -0000 > > <major snip> > .... If you interested in the gory details of this I'd be glad to share it > offline. > Roy > <end snip> > > > Hi Roy and David > I have been following your thread with a lot of interest. > I would like you to continue this discussion on the Digital B&W list. > > I'm just starting wrapping my head around getting the best out of roy's QTR
> and find your discussion very useful. > > > Much thanks > Peter Miles
2003-10-20 by Roy Harrington
I have to agree there's not a whole lot more to say. Since I own neither a 2200 nor a Linux box, I've depended on others to do the testing and calibration. This means its been not a very turn-key solution, but once the values are locked in for a particular printer that issue is closed. Roy --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David Wroblewski" <dawroblewski@y...> wrote:
> Peter, > > There's not more to hear at this point. I'm spending time printing > on my 2200 through QTR using the Epson UltraChrome inks getting > to understand what I can expect from this setup. The output is > so close to metamerism-free and dotless on EEM paper that I'm > thrilled. (It looks like it warms very slightly under > incandescent lighting, and I need a loupe to see the dots at > 5%.) I can mix a warm and cool curve and get pretty much any > range of tone I care about. I haven't felt the need to take > advantage of Roy's offer to share the gory details of calculating > dot size transition points. From a user's point of > view, that's truly esoterica. What I've got works fine, once I > changed one constant in the QTR code and recompiled. > > Next for me will probably be getting a set of UltraTone carts > from MIS. I'd like to understand what difference a set of real > quad inks make, though I'm a little nervous about switching > inks--listening to the discussion so far, I can't get a > definitive reading from the group on the risk of a bad > (i.e. clog-inducing) interaction between the residual > UltraChrome in the pipes and on the parking pads and the > Ultratone inks... in a 2200, not a 1280. > > So that's where things stand for me. I'm very happy with QTR. > It's not a shrink-wrap solution, it requires some learning on the > part of the user, but that's good for me. I like that. I understand > more about B&W printing because my hands are a little dirty. Going > through the calibration exercises alone taught me things I didn't > know. There is a level of precision available to me now that I > had no way of getting to when I was printing directly from > photoshop through the Epson driver. > > The active part of my learning curve right now is bulletproofing > the printing process from Linux so I don't screw up (like I did > this weekend) and print a tif file with an alpha channel and > wind up with an all-black print. And getting the centering of > images to come out correctly. And making sure the output > matches my screen. Etc. > > -David > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Peter Miles > <P.Miles@m...> wrote: > > Roy Harrington Wrote > > Message: 14 > > Date: Fri, 17 Oct 2003 18:03:30 -0000 > > > > <major snip> > > .... If you interested in the gory details of this I'd be glad to > share it > > offline. > > Roy > > <end snip> > > > > > > Hi Roy and David > > I have been following your thread with a lot of interest. > > I would like you to continue this discussion on the Digital B&W > list. > > > > I'm just starting wrapping my head around getting the best out of > roy's QTR > > and find your discussion very useful. > > > > > > Much thanks > > Peter Miles
