New Oriental Paper
New Oriental Paper
2003-10-24 by Jeff Magidson
Has anyone out there tried the long awaited Oriental Fiber Base inkjet
paper?
I just got a 10 sheet package from B&H. 8.5"x11" FB Glossy.
I do not currently have my 1160 printer setup with MIS UT but I will
soon. I can't tell right now how those inks will work with the new
paper.
Some observations... After reading posts on how this paper was supposed
to mimic the look and feel of traditional Fiber prints I was surprised
to see that the paper is actually more glossy than I had expected. Air
dried FB darkroom prints have a dull gloss to them. This paper has a
higher gloss.. closer to the gloss that you get with RC print. I
printed an image on it with my Epson OEM inks. The look and feel of the
paper reminds me a lot of a Webber Valentine (jpg-206)  that I printed
on several years ago. However that is just a surface observation. The
enclosed Oriental Spec sheet says the paper has been developed for
pigment ink. So.. the real test will be in how it takes those inks.
Has anyone made prints on this new paper?
Re: New Oriental Paper
2003-10-26 by Mitch Alland
For: Sanders McNew
> I've printed several images on it using a 2200, Epson inks and QTR,
> and they
> are good enough if you want a highgloss finish -- no problems handling
> the
> pigment inks.   But I haven't seen anything with this paper that would
> lead me to
> start using it.
The real issue about this paper is whether it can produce B&W prints
without bronzing, as all of the other glossy-type papers that are used
with Photo Black ink are subject to unacceptable bronzing. Did you use
Photo Black? Was there bronzing?
--Mitch/Bangkok
