Ingo,
>... filled in the original Epson black ink. It needed a
>few cleaning cycles but then all problems went away.
>It seems that the ebony black didn\ufffdt worked in my printer for
>whatever reason. I am not sure if I want a second try with ebony at
>the moment but with the original epson black I dont get an acceptable
>dmax. Therefore I\ufffdm thinking to have a try with the Epson mattblack
>from the Epson 7600. Could this be a good idea?
I concur with Daniel Staver. The Epson Matte Black measures slightly darker
with the densitometer but is noticeably warmer. I think because of the
warmth, it seems to look slightly less dark in a few of my pictures, so I do
prefer the Eboni. However, the Epson UltraChrome matte (and photo) blacks
are excellent (as are the MIS versions).
As to why the Eboni didn't work, one possibility is that the damper screen
in your 7500 is getting clogged. (Dampers are apparently relatively cheap
and easy to replace.) The Archival black may be a slightly smaller and
smoother particle. The UC Matte black is, for example, slightly larger than
the Photo black. The smaller, coated particles may simply be able to get
through a screen that is just too clogged for larger particles to get
through.
I don't have statistics on the particle sizes, but my belief is that the
Photo black and probably Archival black are about 0.1 micron. The Matte
black is, I think 0.14, and it supposedly has a special surface that helps
it stay in suspension. Some of the pigments average about 0.25 microns. In
general, all else being equal, the larger the pigment particle, the more
resistant to oxidation and fading. The Eboni and PiezoTone Museum blacks
are so good in this respect that I suspect they may be relatively large
particles.
So, if this is what is happening, the matte black may also have trouble --
or maybe not. I'll be curious if it works and isn't too warm for you.
>...I realy would like to get what I see on the monitor.
Be sure to make a custom dot gain curve for the PS preview feature. Tyler
explained the procedure at
http://groups.yahoo.com/group/piezography3000/message/17849
Good luck.
http://www.PaulRoark.com
_______________________________________
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "patchy6513"
<ingo.meyer@q...> wrote:
> Thank you all for your advices,
> yesterday I tried again with a KK1 and KK2 cleaning and ended with
> having emptied two newly filled cartridges. I will fill in the rest
> of the bulk ink (about 20 ml) to have some more test.
> Did anyone have experienced or seen the mentioned horizontal
> misalignements ? Any ideas how they are produced? I really don\ufffdt
have
> clou about them. I will scan the printout and post them here.
> As I said I had already two perfect prints in the beginning. All
> mess started with the ink drops on the paper. Is there something
> disconected or ruptured? I think I have to sort out a few things.
> Here in Germany we don\ufffdt have Windex. I saw this is a usual Window
> cleaner. Does Windex have any special ingredients ? Can I just
choose
> a similar product or is there any danger with other ingredients. I
> read that alcohol can make the problem even worser with some inks.
> Has someone a recommendation for a similar product on the german
> market?
> Ingo
> -- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
> <paul.roark@v...> wrote:
> > Ingo,
> > You wrote, in part:
> > >Is there a way to get the ebony black working well?
> > I'm sorry to hear you're having problems, and I'm no expert in
> theses
> > machines. However, as to whether Eboni can run well in a 7500,
my
> > experience is that it can. All I did with my 7500 is a "prepare
for
> > transport" to drain the Archival black, and then I loaded the UT
> carts,
> > including Eboni. The 7500 has run very smoothly with almost no
> clogs. It
> > sat unused for 10 weeks and only needed 3 cleaning cycles to get
a
> perfect
> > nozzle check. So, it can be done.
> > One thing that I'm very careful to do in loading 7500 carts with
> ink is to
> > be sure all the foam and air is out of the cartridge. When I
> inject the
> > ink, I have the syringe at an angle so that the ink stream hits
> side of
> > the bag and not the pool of ink directly. When full, I slowly
> withdraw the
> > syringe, sucking out the air and foam as I go.
> > In general, we know that Eboni is sensitive to dyes. I'm
> suspicious that
> > Epson Archival K does contain some dye. The 7500 I bought was so
> little
> > used, that it's possible there was not enough dye to matter.
> > MIS recommends that large format printers have a flushing fluid
put
> them to
> > get the dyes out of the dampers. Either I was lucky, or the
> Archival K
> > doesn't have enough dye in it to matter with respect to the
dampers.
> > However, there is also a possibility that, if the 7500 was not
> fairly new,
> > there might be enough dye on the parking pads to cause trouble.
> So, I'd
> > consider rinsing them with Windex and wiping off the surface of
> pads
> > rather thoroughly. Then try to wipe the heads with a Windex-
soaked
> paper
> > towel. That did the trick with my 1280, which was showing
> deflected nozzle
> > check patterns -- possibly evidence of surface solids on the head.
> > Good luck.
> > Paul
> > From: patchy6513 [mailto:ingo.meyer@q...]
> > Sent: Monday, October 27, 2003 3:10 AM
> > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > Subject: [Digital BW] Help needed: Epson 7500 ebony clogged
> > Hello,
> > last weekend I really went through hell.
> > I installed a set of UT in my Epson 7500. After filling the
> cartriges
> > everything went fine so far. I couldn\ufffdt get a good nozzle check in
> > the evening so I waited untill the next morning and it seemed that
> > the problem had settled down. So I tried a first printout with
Pauls
> > curves wich were not bad. Suddenly after another sheet of paper
> black
> > ink purged like drops on the paper and the black was nearly totaly
> > blocked. So I did an "initial fill" cycle to get air bubbles out.
> > After many attempts of cleaning and intitial fill cycles I am
still
> > not getting a good nozzle check or print out. When I print
a "print
> > pattern" from the service menu I can see od horizontal
misalignments
> > in the black. These alignments lines behave like declining curves
> but
> > there are no dots missing. I don\ufffdt have any explanation for that.
> All
> > other inks work fine.
> > Please help with any ideas. Is there a way to get the ebony black
> > working well? I really hope I haven\ufffdt damaged the printer.
> > Another thing: I know some people sucking out ink from the tubes
> with
> > an negativ fill adapter. Can someone give a good description may
be
> > with pictures how to do this?
> > Regards,
> > Ingo Meyer
page.
them short.
resources on the homepage.
