Re: levels destruction in adjustment layers?
2003-10-31 by bruce greene
I think that one might be better off using  many adjustment layers
instead of many single adjustments (talking 8 bit files here).
By using adjustment layers only one render will take place instead of
multiple rerendering of the image.
What I  don't know for sure is whether the final result will be
different using the two techniques. I expect a better result from the
multiple adjustment layer approach.
If you are just using one adjustment layer, I don't believe there would
be any advantage in that approach vs. one curves correction.
On Friday, October 31, 2003, at 01:56 AM,
> Steve
> I don't think I was very clear as the responses have gone off on a
> tangent. I DO definately get degradation with 8 bit adjustments. I
> just wondered if there was any advantage to THE FINAL PRINT by doing
> those adjustments in an adjustment layer as opposed to the actual
> image file.
> Garry Sarre
> www.sarre.com.au
