Levels destruction in adjustment layers?
2003-10-30 by Garry Sarre
I try to do all levels and curves in 16 bit as 8 bit adjustments
pull the image apart like an undercooked pizza base.
Sometimes there is fine tuning done in 8 bit, often with adjustment
layers. Now I know these don't interfere with the original file,
however, taking for example... a moderate stretch of the levels in
an adjustment layer and then those two layers flattened for
printing. Would that lead to the same degradation (good word for
this) as if it was applied directly to the image layer. In other
words, would there be the same solarized appearance as the end
result.
Garry Sarre
www.sarre.com
Re: Levels destruction in adjustment layers?
2003-10-30 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Garry Sarre"
adjustment
> result.
> Garry Sarre
> www.sarre.com
Garry;
I'm sure someone will correct me if I'm wrong, but I don't think
most of these printer drivers are capable of processing a layered
image-at some point it has to get flattened and your adjustments
applied so doing as much as possible in 16-bit makes sense, at least
in theory. However,I seem to remember some rip-snorting arguments on
this forum as to wether or not you could actualy see the damage in a
print.
Steve Karafyllakis
Re: [Digital BW] Re: Levels destruction in adjustment layers?
2003-10-30 by Tom Baker
I'm beginning to wonder about the actual visual degredation as well.  I want to get some time to try to prove/dis-prove this.  At least to my own satisfaction.
I believe that there is probably a lot of math/science that says there is degradation.  But, I want to see under my particular conditions and expectations.
Tom Baker
adjustment
> result.
> Garry Sarre
> www.sarre.com
Garry;
print.
Steve Karafyllakis
Yahoo! Groups Sponsor
2003-10-30 by Stephen Kobrin
Steve,
I cannot speak to more complex layers, but I do use an adjustment
layer at times to make last minute corrections before printing and
Epson printers seem to handle it without a problem.  They are simple
curves adjustments for brightness or contrast.
Steve
least
on
a
> print.
> Steve Karafyllakis
RE: [Digital BW] Re: Levels destruction in adjustment layers?
2003-10-30 by Paul D. DeRocco
> From: Tom Baker [mailto:tbaker1328@...]
For the most part, the answer to the question depends upon how much noise
(either CCD noise or film grain) is in the image. If the peak-to-peak
amplitude of the noise is more than about four or five (in an eight-bit
image), then there is nothing to be gained by preserving more than eight
bits of resolution.
In practice, this means that for inexpensive, small-CCD digicams, eight bits
is enough, but for better digicams (e.g., 10D) or film scanners, you can
indeed see posterization in an 8-bit image.
2003-10-31 by Steven Karafyllakis
Steve;
Not what I meant, exactly. I send layered files (6-8 deep sometimes)
to the printer too. It 'handles' them by flattening or applying them
in some way, otherwise you wouldn't get the adjustments or a
composite image, etc. Bottom line is your printed image has had
those adjustments applied-wether you can see degradation or not I
think depends on...how extreme it is? I've seen choppiness (abrupt
changes in tonality were there should have been a smooth ramp)in the
lower values that I attributed to degradation, but it's rare, and
I've never taken the time to prove/disprove the idea either
Steve Karafyllakis
> Steve,
simple
> Steve
layered
> least
arguments
> on
in
> a
> > print.
> > Steve Karafyllakis
2003-10-31 by Garry Sarre
least
on
a
> print.
> Steve Karafyllakis
Steve
I don't think I was very clear as the responses have gone off on a
tangent. I DO definately get degradation with 8 bit adjustments. I
just wondered if there was any advantage to THE FINAL PRINT by doing
those adjustments in an adjustment layer as opposed to the actual
image file.
Garry Sarre
www.sarre.com.au
2003-10-31 by Paul D. DeRocco
> From: Garry Sarre [mailto:garry@...]
> image file.
Until you get PSCS, which has 16-bit adjustment layers, you're probably
better off _not_ using adjustment layers, and staying in 16-bit mode. That
way, the adjustments won't cause posterization. The result will still get
converted to 8-bit data on the way to the printer driver, but at least each
gradation with be 1/256th of the range, instead of getting some gradations
that are only 1/128th of the range.
You sound like you're one of those people who really need PSCS.
2003-10-31 by Jeff Borkowski
does anyone have a top-rate drum scan vendor they like to use who is
scanning 16bit and can scan negatives up to 7x17in?
also, does anyone have experience with Photoshop CS's enhanced support for
16bit workflow?
  Sent: Thursday, October 30, 2003 9:39 PM
  Subject: [Digital BW] Re: Levels destruction in adjustment layers?
  least
  on
  a
  > print.
  > Steve Karafyllakis
  Steve
  image file.
  Garry Sarre
  www.sarre.com.au
              ADVERTISEMENT
page.
them short.
layered
> least
arguments
> on
in
> a
> > print.
> > Steve Karafyllakis
> Steve
doing
> image file.
> Garry Sarre
> www.sarre.com.au
Garry;
Sorry, you're right we are of on a tangent; My take is that there is
no advantage to the final print; the advantage is in keeping your
file in good enough shape to re-adjust as often as you like with out
accumulated degradation. BTW I got a MAC Mall catalogue in the mail
yesterday, they had a 4-page add on PSCS, I hope it gets released on
time; this is one time I'm willing to put up with product activation
w/out complaints!
Steve K
2003-10-31 by John Vitollo
> Garry; I got a MAC Mall catalogue in the mail
> w/out complaints!
> Steve K
Hey Steve, it's now shipping! Got mine today! Don't know about Windows but on the
Mac it's faster than Photoshop  7.
Mac has no activation this time around but maybe next year.
2003-10-31 by John Swain
My experience was exactly the opposite. if I don't flatten the image before
printing I get posterisation.  It took me a while and many prints to work
out that it was the adjustment layers causing the posterisation.
I am using
- Mac OSX
- Epson Print Driver
- Roak NCA Curves
- MIS UT Inks
My workflow is now:
- Convert to 8 bit
- Adjust levels in Adjustment Layers
- Flatten
- Unsharp mask
- Apply Roark Curves
- Print
This is producing the best prints I have ever made, but would be interested
to know if I the above process could be further improved.  Sounds like
Photoshop upgrade would help with 16bit adjustment layers.
js
Sent: 30 October 2003 21:34
Steve,
Steve
least
on
a
> print.
> Steve Karafyllakis
page.
them short.
> From: John Swain [mailto:john.swain@...]
> My workflow is now:
> - Convert to 8 bit
> - Flatten
> - Unsharp mask
> - Print
> interested
You might try doing the adjustments before converting to 8-bit. This of
course precludes the use of adjustment layers (until your copy of PSCS
arrives), but in 16-bit mode, who cares?
2003-11-01 by Bill
The file is certainly flattened before it reaches the priinter though.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin"
<kobrins@w...> wrote:
> Steve,
> Steve
> least
> on
> a
> > print.
> > Steve Karafyllakis
