foamboard in s. florida
2003-10-31 by Boris Wiedenfeld
hi there.
anyone know a supplier that sells 32x40 sheets of foamboard for a good
price in south florida?  (pref. in palm beach or lauderdale)  I'm tired
of mail-ordering that stuff.
thanks in advance
boris
www.bawphoto.com
Okay - making the plunge - questions
2003-10-31 by Allan B Chen
All,
Okay - so I'm finally going to do it - going to order a 1280 and start off
with the UT inkset.  I therefore have a few questions about exactly what
I'll need, and what I should do.  Now, I know that much of this has been
mentioned at various points, but my composite understanding of the process
is a bit unclear, and I'm a bit confused by all the options on the MIS
website.  So...sorry for the possibly annoying questions.  Let me see if I
got this straight:
-is there an advantage (other than cost, presumably), to filling my own
carts rather than buying the pre-filled ones?
-do I need to run the Epson inks through the printer first to make sure
everytyhing works?
-when I switch to the UT inks, do I need to wait some time before actually
printing?  I read a reference to something like that, but am unsure.
-Do I need to get the cleaning cartridges from MIS, or will simply putting
in the UT carts and running the purge pattern for 5 or so prints be
sufficient?  The MIS page says just run the pattern, but some of you have
mentioned using the clear fluid cleaning cartidges.
Any other general tips and hints to help ensure a smooth setup?
thanks,
allan
RE: [Digital BW] Okay - making the plunge - questions
2003-10-31 by Paul Roark
Allan,
>1280 and start off with the UT inkset.  ...
Probably not.  In fact, to ease the transition into the new venture,
starting with pre-loaded carts might make sense.
>make sure everytyhing works?
I'm not sure there is a 100% answer to this one.  I once heard that the
substance Epson puts in the new heads to preserve them on the shelf is best
removed with their own inks.  On the other hand, I'd rinse the dyes off the
parking pads if the OEM inks are used.
>before actually printing?
The waiting time is usually only with carts you load yourself, not the
pre-filled ones.  Bottom-loaded carts can get air bubbles in them that will
often cause problems, but they tend to float up and out of the way if the
printer is let sit overnight.  Frankly, I fill, insert and print
immediately.  Sometimes I need a cleaning cycle, but often not.
>-Do I need to get the cleaning cartridges from MIS, ...
MIS doesn't think there is enough dye in the desktop printer heads to cause
any problems.  I never bother with the flushing fluids.
Dive in and have fun.  The settings and workflow are critical, so be sure to
follow it carefully.
Enjoy.
http://www.PaulRoark.com
Re: [Digital BW] Okay - making the plunge - questions
2003-11-01 by D. Hill
Allan,
Weighing the options of running the dyes through first
in my virgin 1280 or starting with the final inkset
was a big question.  Most of the 1280's are pretty
robust machines direct from manufacture, as well as
calibrated so I just primed the machine with
piezotones.  I could not be happier with the results
as well as not having to clean the dyes out of the
machine before loading the quadtones.  I have not had
one clog or issue with this printer over the last 4
months.
Don
> first to make sure
> everytyhing works?
> thanks,
> allan
Do you Yahoo!?
Exclusive Video Premiere - Britney Spears
http://launch.yahoo.com/promos/britneyspears/
