New and confused.
New and confused.
2003-11-01 by Ivan Goldberg
I wish to use my 1280 and Paint Shop Pro 8.0 to do black & white printing. Does anyone know what inks are compatible and what additional software I will need?
TIA . . .
Ivan
|-------------------------------------------------------ooOo-( )-oOoo----
                               Ivan Goldberg, MD
 V 212 876 7800    1556 Third Ave NYC 10128    F 212 876 7821
            http://www.psycom.net/quotations.html
        http://www.psycom.net/depression.central.html
             http://www.psycom.net/bookstore.html
    If you assume that there's no hope, you
      guarantee that there will be no hope. If
      you assume that there is an instinct for
      freedom, there are opportunities to
      change things, there's a chance you may
      contribute to making a better world. That's
      your choice.
                                -- Noam Chomsky
Re: New and confused.
2003-11-02 by Tom OConnell
Hi Ivan-
I'm not really familiar with PS 8, but the earlier versions seemed to
do most or all of what you need.
First of all, you need to settle on a preferred method of converting
to BW. Volumes are written on this and available across the internet
and in books...pick any one to start your printing process and then
learn varatitions from there...probably there is a "convert to
grayscale" option in PS. (won't be the absolute best way to do it,
but will get you started).
Next you have to decide on what ink method you will use. there are
basically 3 choices: Black ink only (not very popular since it is
less able to translate tones), third party black inks (most of the
discussion is among folks using 3p inks like those from MIS) or try
getting a perfect profile and using the Epson inks to make BW (very
unlikely and almost impossible).
there are a lot of other choices you have to make such as cartridges
or continuous ink, etc but you should just try some cartridges first
and try a couple of inks to see what you like. Go to the MIS,
Piezography, Lyson, Inkjetgoodies, InkjetArt and see what they have
to offer...you can learn a lot looking at the vendor sites and then
you might come back here with a more precise question or two...but
mainly just try out one or two options first...it isn't nearly as
hard as it sounds...jump in.
Tom O'Connell
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ivan Goldberg
> TIA . . .
> Ivan
oOoo----
>                                Ivan Goldberg,
MD
>       your choice.
>                                 -- Noam Chomsky
