Hello Rick,
I have been; and am, still like you; seeking the ultimate black in my
black and white images. I assume you have calibrated your monitor to
show absolute black when it is present in the image. There are so
many techniques available to do this that I hesitate to cite any
particular one for fear of the group jumping in and telling me what
is wrong with that one; but if it works for me, then it's right for
me and I can reproduce the same results on a regular basis. The one I
use is to use the desktop to determine absolute black. Move all icons
to a folder while doing this and make the desktop true black (RGB
0,0,0). Slide the screen down so that there is an unscanned area
above the black desktop. Using the eye, which is the instrument we
use to determine the black in the image, match the desktop black with
the unscanned part of the CRT tube black. This gives you the true
black to compare with in your image. Recover the standard desktop you
had before doing all this jazz and then switch to Photoshop and your
image to see the difference in the image as the result of making this
change. Make adjustments to the image to your liking and see if this
image has a real black. I do make the default values on the curves to
0,0,0 for the black point and 243,243,243 for the white point which
allows for specular highlights to be present in the print if they are
present in the image. The inkset I use is MIS Full Spectrum Neutral
and the PiezoBW plugin for printing. I am getting closer to my
ultimate black and white image prints than I was when I started this
quest. Let me know your ideas on this if you would.
Your friend in photography,
Johnny Eades
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "morganbaily2000"
<rickz1@a...> wrote:
> I am using an Epson 1200 and have been experimenting with various
ink
> systems searching for the ultimate black. I have used Cone's Piezo
> system and was not happy with the tones. I just bought the MIS
> variable mix system and still not happy. Before trying yet another
> combination, what are the groups experiences with the other MIS
> combos...ie full spectrum with the Piezo driver or the original
quad
> system. I have also used Black only printing with a Epson 1270 and
> epson oem ink and love the black tone. I have learned through the
> group that this is the least best way to go because of color fading
> and metamercism. What combo should be used to garner the best
blacks
> with the least amount of fading. As usual thanks in advance for
> help.
> Rick Zeidman
> www.morgan-baily.com
