Vertical banding with QTR 2
2003-11-02 by candlefarmer
I've recently started experimenting with the Harrington Quadtone RIP v2. I'm using the
latest beta on an Epson 2200 with the standard Epson inks. Generally the results are
outstanding but I continue to have one show-stopper problem: vertical banding in
dark areas of the print. This seems to be specific to the QTR RIP - the same image
printed using the epson driver shows no such banding.
It seems to be independent of resolution. I typically use 720x720 but see it in higher
resolutions also.
I originally thought that the banding was due to excessive ink in dark areas. I tried
lowering the ink limit but the banding remains.
I've posted an example here:
http://home.comcast.net/~baur/banding.html
Is this something others have seen? Any help in taming this would be appreciated. (I'm
trying to get a couple of things printed for a show and this is driving me batty.)
Re: [Digital BW] Vertical banding with QTR 2
2003-11-02 by Carl Schofield
Which paper and profile are you using?  I haven't seen this artifact
before, but I do all of my printing at 1440x720 Highest Quality only.
The bands almost look like roller marks patterns, but probably are not.
Carl
> v2. I'm using the
> the results are
> banding in
> the same image
> see it in higher
> resolutions also.
> areas. I tried
> appreciated. (I'm
> driving me batty.)
> Rent DVDs from home.
> Over 14,500 titles. Free Shipping
> & No Late Fees. Try Netflix for FREE!
> http://us.click.yahoo.com/I3w.vC/hP.FAA/3jkFAA/ucIolB/TM
> Please visit the Group Homepage to check the Files, Bookmarks, Polls
> and other resources as they are often being updated. The page is at:
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> - As the topic of a thread changes remember to change the subject
> header.
> - Good manners are required at all time. No personal attacks or flames
> - Before posting a question, search the message archives and the
> various resources on the homepage.
> Your use of Yahoo! Groups is subject to
I just recalled some problems we had with curve breaks in the shadow
areas, before the 2200 dot size weightings were adjusted, and that may
be the source of your problem in this particular image.  I believe that
Roy is planning to release an update that may correct this problem.
Carl
> v2. I'm using the
> the results are
> banding in
> the same image
> see it in higher
> resolutions also.
> areas. I tried
> appreciated. (I'm
> driving me batty.)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield <scho@m...>
Sorry - should have mentioned that: I'm using Epson Enhanced Matte with the
EEM_2200-{cool,warm} profiles.
2003-11-02 by Roy Harrington
As Carl mentioned 1440x720 Highest Quality is the resolution that has
been most tested and calibrated.   So I'd recommend that.
I really don't know the cause of the strange banding that your example shows.
Its possible that some of the driver dot size tuning will fix it but I'm not
sure.
Roy
> Carl
> > v2. I'm using the
> > the results are
> > banding in
> > the same image
> > see it in higher
> > resolutions also.
> > areas. I tried
> > appreciated. (I'm
> > driving me batty.)
Carl/Roy - Thanks for the replies. I have tried 1440x720 - in fact that's how I started
with this particular print. The results were, if anything, worse.
Today I'll try again and vary the ink limit a bit to see if I can make some progress.
Any thoughts on when/how the 'dot-size tuning' will be available?
Thanks again.
> sure.
2003-11-02 by Ernst Dinkla
Sent: Sunday, November 02, 2003 8:16 AM
Subject: Re: [Digital BW] Vertical banding with QTR 2
Quadtone RIP
> > > v2. I'm using the
Generally
> > > the results are
problem: vertical
> > > banding in
QTR RIP -
> > > the same image
720x720 but
> > > see it in higher
> > > resolutions also.
ink in dark
> > > areas. I tried
would be
> > > appreciated. (I'm
this is
> > > driving me batty.)
On the colorsync list was a discussion about vertical banding as
a result of less ink used in linearised RIPs if compared to the
Epson driver's use of ink. By that lower quantity of ink the
imperfections in paper and papercoatings are more prone to show.
I have my doubts about that explanation but you may try to turn
the paper 90 degrees to see whether there's a relation to the
papermaking process. If the banding is very regular in frequency
then it is unlikely that it has anything to do with the
papermaking. And your examples are more like that. Have you
checked the imagefile (brighten + contrast) whether it shows
similar banding as a result of scanning for example ?  It may be
that QTR2 reveals it and the Epson driver doesn't.
Ernst
Re: Vertical banding with QTR 2
2003-11-09 by J Michael Sullivan
I saw a similar banding when using the QTR 2200 profiles on my 9600 -- the cause
was over inking in the midtones (the 9600 drops down more ink than the 2200). Not
sure how this might be happening with your 2200 setup. With the QTR 2200 profiles
my 2200 prints look spot on.
Still trying to get the 9600 to duplicate the quality of the 2200!!
mjs
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "candlefarmer" <yahoo@r...>
are
higher
> resolutions also.
(I'm
