Internet security and firewalls...OT
2003-11-05 by sceptre12345
Lately I've been looking at firewall software packages to replace a
freeware that I've been using for some time. It kept all ports closed
but one, the Ping Echo port which would acknowledge any ping request
from the net.
Ping requests are sent by, amongst others, hackers and spammers
looking for unprotected computers which they can later use for
massive email spamming or even denial of service attacks.
After looking at several firewall packages, I've finally decided on
an SMC Barricade (SMC7004ABR) It's a 4-port 10/100 Mbps Broadband
Router. It allows for up to 4 computers to connect to one internet
connection, cable or even 56k modem.
But the best thing about it is that it provides the firewall
protection that I need for only $29.95 canadian after instant and
mail-in rebate or about $23.00 US. I'm sure it's about to be replaced
by a newer model, but the price is right and it does the job: my
computer no longer responds to ping requests and all other ports are
closed.
http://www.futureshop.ca/catalog/proddetail.asp?
logon=&langid=EN&dept=0&WLBS=fsweb9&sku_id=0665000FS10008877&catid=&ne
wdeptid=18
This link is rather long, dont forget to copy and paste the missing
caracters into your browser.
If you want to test your computer's vulnerability to online threats :
Symantec Security Check
http://security.symantec.com/sscv6/default.asp?langid=ie&venid=sym
Gibson Research Corp.'s ShieldsUP!
https://grc.com/x/ne.dll?bh0bkyd2
I sure hope that this is not too far off topic, but as a digital b&w
printer I do use the internet to subscribe to this list. Please dont
flame me!
Hope this helps,
Andre
Re: [Digital BW] Internet security and firewalls...OT
2003-11-05 by Anthony G. Atkielski
If your system/network is otherwise secure, there's no harm in
responding to pings.
Re: Internet security and firewalls...OT
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Anthony G.
"Ping is a network troubleshooting utility. It asks your computer to
acknowledge its existence. If your computer responds positively to a
ping, hackers are more likely to target your computer."
In checking the traffic log of the old firewall I could see ping
requests from all over the world. But they do not stop at the first
ping, they go on and on. Put several of them together and you've got
what looks like a network slowdown.
Internet denial of service attacks works in the same way, but at a
more intense level. Giving your internet connection stealth status is
one way to ensure you get the maximum speed from your connection.
Andre
Re: [Digital BW] Re: Internet security and firewalls...OT
2003-11-05 by Brentley Beerline
it is fairly standard practice in the security arena
to discard ping protocol requests. The siemens is a
pretty good device and you got a great price on it.
brentley
> "Anthony G.
> later use for
> attacks.
> there's no harm in
> your computer to
> positively to a
> computer."
2003-11-05 by Jon Dubovsky
Please note, however, that RFC 1122 (Requirements for Internet Hosts)
states in section 3.2.2.6:
"Every host MUST implement an ICMP Echo server function that receives
Echo Requests and sends corresponding Echo Replies."
Nowhere in 1122 (which is *the* spec for this sort of thing) does it say
that ICMP Echo (ping) servers may be disabled or set to ignore ICMP Echo
packets.  The sole exception is for an ICMP Echo packet destined for a
broadcast or multicast destination IP.  Disabling Echo Replies makes
your TCP/IP implentation non-compliant with the standard.
I'm in the business of making tools to make the Internet, and systems
with ICMP Echo Reply disabled prove to be a real pain for network
people.  "Ping" is there for a very good reason.  It isn't dangerous.
Please leave it enabled if you possibly can.
[diatribe: off]
Best wishes,
Jon ( entropy@... )
> Cheers,
> Andre
2003-11-06 by Anthony G. Atkielski
It also prevents network problems from being tracked correctly, since
your machine is effectively invisible.  If you are operating any kind of
server, it's a good idea to answer pings.  If your machine is strictly a
client, it's less important, but then again, it's less of a risk, too
(since you should have fewer ports open).
RE: [Digital BW] Re: Internet security and firewalls...OT
2003-11-06 by Paul D. DeRocco
> From: Anthony G. Atkielski [mailto:anthony@...]
A lot of large servers don't respond to pings, like www.microsoft.com. I
suspect it's because whenever someone wants to make sure their DSL isn't
dead, they ping www.microsoft.com, and they just got tired of the millions
of pings.
Re[2]: [Digital BW] Re: Internet security and firewalls...OT
> of pings.
I don't know why they turned off ping replies, but network load can't be
the reason.  With the load they are already carrying for everything
else, the load from pings isn't going to make much of a dent in
anything, either for bandwidth or for server horsepower.
