Thanks Martin.
Yes, I know I'm not supposed to individually give thanks on the
forum, but many times when I have asked, it was only you that
responded. Again, thank you.
Terry
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Martin Wesley"
<mwesley250@e...> wrote:
> * -----Original Message-----
> * From: Terry [mailto:teelions@y...]
> * Sent: Saturday, November 08, 2003 8:52 PM
> * To: DigitalBlackandWhiteThePrint@yahoogroups.com
> * Subject: [Digital BW] MIS VM & R9
> * Does anyone have any experince using MIS VM inks with the R9
plugin?
> * How are your prints compared to using the inks with the curve
> * profiles? What papers do you fine work best? which ink set do
you
> * find works best?
> Terry,
> The R9 will not work at all with the MIS-VM inks. If you print
using the two
> you will get a weird print that is blue in the midtones since one
of the
> gray inks is replaced with the Cyan tinted toner ink.
> Basically ink sets and software are designed specifically to work
with each
> other and are not interchangeable. The R9 plug-in will work with
Sundance
> inks, Piezotone inks and MIS Full Spectrum which gives you a total
of about
> 9 different ink sets to choose from. Or you can use the VM with the
RGB
> separation curves or with a RIP that supports that ink set.
> Martin Wesley
> http://www.carolyn.cc/Guests/MartinWesley/pages/MW_01.html
> http://www.borderless-photos.de/guests.html
