need advice on new equipment
2003-11-11 by ArleneLoveL@aol.com
I need advice on upgrading to new scanner & printer
I work in 35mm, exclusively in B&W (Kodak T400CN). My present scanner is 2720
dpi and my Epson 3000 prints max 1440 x 720. Different tech experts tell me
different things. One says get a Minolta DiMage 5400 and another says Nikon
8000. The price difference is enormous, and the Nikon scans medium format, which
I don't use, so why pay for it? The Minolta scans at 5400, and the Nikon scans
at 4000. What's your consensus?
I use PS7 and MIS quad inks carts.  Trying to fill the carts was a disaster,
and I won't even contemplate CIS.
Is there an advantage to upgrading my printer from a 3000 to a 7500 when they
both print at a max 1440 x 720? The 7600 is 2880x1440 - and is $3000! It
would be a big stretch - is it worth it?    I will continue to dedicate my printer
to B&W , and my prints are always 11 x 14 and 16 x 20. Can a  35 mm neg  go
larger? I appreciate all the input you can give. I'm not a techie and don't
understand half of what you all talk about, but am boundlessly grateful for this
forum. Thanks to all.
                     Arlene
Re: need advice on new equipment
2003-11-11 by sceptre12345
Nikon has announced three new scanners, two of which may interest you,
the Nikon 5000 and the Nikon Scan V.
They are 4000 dpi scanner with better dmax than previous models.
Stated DPI is not everything. Real dpi is, as is dmax.
You may find that your Epson 3000 printing better images with scans
from one of these scanners.
http://www.letsgodigital.net/en/news/articles/story_522.html
Andre
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, ArleneLoveL@a...
scanner is 2720
tell me
says Nikon
format, which
Nikon scans
disaster,
when they
$3000! It
dedicate my printer
neg  go
and don't
grateful for this
>                      Arlene
2003-11-11 by heavylens
Hi -
If you don't need a medium format scanner, you are spending a lot of money for nothing.  I have a Microtek 4000tf and it is doinf a
good job for me.  The resolution is so high (4000 ppi) that I usually see the grain of the film rather than the pixels.
2003-11-12 by Bob Michaels
Try to honestly evaluate if you JUST WANT a new scanner and/or printer
or if you want better looking prints. If you just want new hardware,
simply buy the what you want the most.
But, if you want better looking prints, scan a neg in your old scanner
then mail the neg to someone who will scan it for you on the scanner
you're considering and send back a file. Manipulate both files best as
you can, then print both. Mark on the BACK of each print which is
which. Put them away for a day or so, then shuffle them and try to
decide which is better. And if you can tell the difference and the one
you like better is with a different scanner, decide is it's worth the
money.
Repeat a similar process with the new proposed printer, having someone
print an identical file. Compare the prints without knowing which is
which.
My way is almost too practical and not near as much fun. In fact, if
most people did that with cameras or lenses, they'd not buy new ones,
and constrict the market for new products. But it does work.
Bob Michaels
scanner is 2720
tell me
says Nikon
format, which
Nikon scans
disaster,
when they
$3000! It
dedicate my printer
neg  go
and don't
grateful for this
>                      Arlene
RE: [Digital BW] need advice on new equipment
2003-11-12 by Paul Roark
Arlene,
>My present scanner is 2720 dpi and my Epson 3000
>and another says Nikon 8000. ...
Buying a Nikon 8000 just for 35 mm doesn't make sense to me.  Get a good 35
mm, 4000 (or 5400) dpi scanner.  With T400CN, the difference between 4000
and 5400 dpi is probably irrelevant.  What would be most important to me is
to get the scanner with the best grain reduction program.  I shoot T400CN
also, and the grain reduction algorithm on my 8000 is really nice to have.
The 35 mm version of this scanner has the same features.  Also, the dust
removal option saves a lot of time with T400CN.  The Nikon has this; I'm not
sure of the others.  I'd search the internet for tests that compare the
Nikon, Minolta and competitive Canon and see how these grain reduction and
dust removal programs compare on these scanners.
>3000 to a 7500 ...
The 7500 handles thicker paper much better than the 3000.  If you use thin
paper (like Epson Enhanced Matte), that might not be a big issue.  With the
Epson 4000 coming out there will be more papers in 17" widths.  That will
help those with old 3000s.  With 35 mm, I would not recommend going above
16x20.  In fact, I'm finding that the larger prints I make with the 7500 are
usually too large for the display areas and a hassle to store.  So, if your
3000 doesn't band and is handling the paper you like, I'd save your money
(maybe for a 4000 next year).
http://www.PaulRoark.com
2003-11-12 by amateriat
From one reluctant techie:
Three weeks ago - give or take a few days - I got a Minolta 5400.
Proceeded to lash it to my system (Power Mac 7600 with
newly-installed 500mHz G3 upgrade, Epson 1270 [color] and
1160 [b/w]). Made a few tests. Made a few prints (11x17" for b/w,
13x19" for color). Jumped out of my chair...for "quickie" scans
made with a minimum of "A-R"*  fuss, this was wonderful -
detail, scale, and...no interpolation! No more "digital Hamburger
Helper" for large prints.
I'm now convinced that you can never have too much RAM *or*
scanner resolution, even for 35mm. I saw the difference in scans
with the "broken" Polaroid SprintScan 4000  I was given a little
while ago (and sucessfully fixed) compared with my previous
Minolta (2900, which my 5400 replaces). I can also see the
difference the 5400 makes over the Polaroid. Overkill for certain
films? Maybe (a scan of Neopan 400, pushed one stop, probably
benefitted marginally, but benefitted nonetheless), but I also
shoot with a few slow films, including Konica Impresa 50, which
absolutely benefits (ask Paul Roark about this film - he did
something amazing with it in tandem with my favorite compact
35, a Ricoh GR1). Color print tests on an Epson 2200 I got just
last week drive the point home even harder.
As for the new Nikons, the only advantage I can see is in
scanning speed. So it's a question of speed versus resolution,
perhaps, but resolving power is hardly all the 5400 offers (too
much for me to go into here). I can only speak for myself, but I'm
absolutely sold on it.
As for upgrading the 3000: I'd try a new scanner first, then
decide; the benefits of casting aside the necessity of
upsampling for larger prints, IMO, cannot be overstated. And the
Epson 3000 is a solid printer for b/w.
And, if you'd like, I'll gladly make a scan of a negative for you to
test-print (he says while racing to put his new computer system
together).
- Barrett
>present scanner is 2720 dpi and my Epson 3000 prints max
>1440 x 720. Different tech experts tell me different things. One
>medium format, which I don't use, so why pay for it? The Minolta
>scans at 5400, and the Nikon scans at 4000. What's your
>consensus? I use PS7 and MIS quad inks carts.  Trying to fill
>the carts was a disaster, and I won't even contemplate CIS.
>7500 when they both print at a max 1440 x 720? The 7600 is
>2880x1440 - and is $3000! It would be a big stretch - is it worth
>it?    I will continue to dedicate my printer to B&W , and my prints
>are always 11 x 14 and 16 x 20. Can a  35 mm neg  go larger? I
>grateful for this forum. Thanks to all.
>                      Arlene
Re: [Digital BW] Re: need advice on new equipment
2003-11-12 by Steve Kale
I understand that these will be available in the Spring.  Has anyone heard
anything about pricing?
Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com
Date: Tue, 11 Nov 2003 22:16:31 -0000
Subject: [Digital BW] Re: need advice on new equipment
Andre
