Suggestions for printing on an Epson 1160
2003-11-13 by Allen Birnbach
I bought an Epson 1160 a couple of years ago, bought some MIS and Cone inks to do
the Roark color variation in black and white (before MIS was mixing warm inks). I did
a few test prints, then put the machine on the shelf and have not used it since.
I'm wondering if I could ask for current thinking on using the Epson 1160 in terms of
inksets and papers to get high quality black and white prints.  In general, I prefer the
warmer valued, as I traditionally printed with a split toned carbomide technique in the
darkroom on Agfa Classic gloss, dried matte.  Thanks in advance for any suggestions.
Re: Suggestions for printing on an Epson 1160
2003-11-13 by Jeff Randall
Allen:
If you want to be able to vary the warm/cool tone of your prints then
check out MIS VM inksets and use Paul Roark's workflow.  If you don't
want to vary the tone, then check out the MIS FS (slightly warm) or
FSN (neutral) inksets and use the 1160 RGB partitioned workflow. Both
the Roark and 1160 RGB workflows are posted on the MIS workflow pages
and in the files section of this forum.
The 1160 RGB workflow is at--
Files>Ink Sets>MIS>MIS FS>Jeff Randall's Workflow
The 1160 RGB workflow works well with FS or FSN inksets on EAM/EEM or
Photorag.
Good luck.  Let's us know how you progress.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Allen Birnbach"
Cone inks to do
warm inks). I did
used it since.
any suggestions.
2003-11-13 by Mark Hahn
I am using the 1160 and MIS VM with Roark UT curves and am producing
excellent "warm" and "medium warm" prints pretty much out of the
box.  I recently took some of my "warm" prints to a gallery and felt
that they compared very well with another photographers palladium
prints.
mark
Cone inks to do
warm inks). I did
used it since.
any suggestions.
Mark, what paper are you using, and can you give an online vendor for it?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark Hahn"
> prints.
> mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jeff Randall" <jrandall@c...>
> Photorag.
Sorry, but what specifically is EAM/EEM or Photorag, and where could I purchase
those to test?
Thanks.
Re: [Digital BW] Re: Suggestions for printing on an Epson 1160
2003-11-14 by Jeff Magidson
I too have made prints with the MIS VM inks. However, I would not
recommend them. After prints that I made with the warm and medium warm
curves where exposed to indirect daylight for a few weeks they started
to warm and continued to warm to an unattractive tone. Other users have
reported that prints made with VM inks using the cooler curves don't
warm. I had heard of this warming effect before I began using the inks
but I was surprised to the degree of warming that occurred in such
relatively  little time and with such moderate light exposure.
For this reason alone I would use the MIS UT inks that are reported to
be "non warming". In addition I am finding that the tonal options that
are possible with the UT inks are much more pleasing than the VM inks.
-Jeff
> prints.
> mark
2003-11-14 by Jeff Randall
EAM=Epson Archival Matte
EEM=Epson Enhansed Matte (new name for EAM)
Photorag=Hahnemuhle Photorag (often rebranded)
Check out Atlantic Exchange for Epson papers.
Check out InkjetGoodies (and many others) for Hahnemuhle papers.
Jeff Randall
<jrandall@c...>
EAM/EEM or
> > Photorag.
could I purchase
> those to test?
> Thanks.
2004-01-06 by Allen Birnbach
do
did
of
suggestions.
By the way, I found my old inks.  The four Cone Neutral Quadtone inks for black,
magenta, yellow and cyan positions all say use before February 03. Do these really go
bad?
I also have two containers of MIS ESC-ARC-4PC which I labeled VP3.
I also cannot find the information by Paul Roark explaining how to make this all work
(we moved recently), and I cannot find anything in the files that looks like it will help.
So, is it possible to work with these old inks, or do I simply need to start over? Any
thoughts would be appreciated.
