QTR question for Roy et al
2003-11-14 by Steve Kale
I am trying to instaall QTR on a friends G5 Panther system amd all went smoothly except that when I try to set the Quadtone Settings under Printer Features in the driver it does not exist.... I have reinstalled QTR to no avail. Gimp 4.2.5. Ghostscript done. Espon 2100 printer. What am I missing? Steve
2003-11-14 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale" <stevekale@b...> wrote: > I am trying to instaall QTR on a friends G5 Panther system amd all went smoothly > except that when I try to set the Quadtone Settings under Printer Features in the > driver it does not exist.... > > I have reinstalled QTR to no avail. Gimp 4.2.5. Ghostscript done. Espon 2100 printer. > > What am I missing? > > Steve Steve, It sounds like when you Added the printer you didn't select the the QuadToneRIP version of the driver. See the first screen capture in the ReadMe file of the distribution. Roy
Ah yes...knew it was something stupid...the problem with trying to do something in too short a time window Thanks Steve --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington" <roy@h...> wrote: > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale" <stevekale@b...> > wrote: > > I am trying to instaall QTR on a friends G5 Panther system amd all went smoothly > > except that when I try to set the Quadtone Settings under Printer Features in the > > driver it does not exist.... > > > > I have reinstalled QTR to no avail. Gimp 4.2.5. Ghostscript done. Espon 2100 printer.
> > > > What am I missing? > > > > Steve > > Steve, > > It sounds like when you Added the printer you didn't select the the > QuadToneRIP version of the driver. See the first screen capture in > the ReadMe file of the distribution. > > Roy
2003-11-24 by foggy11dj
After great luck with QTR on an Epson 7500 with Ultrachome Inks and EEM I am now trying to get QTR to work on my Epson 1200 with with Media Street Generations 6- color ink set. I can't seem to find any curves out there to use as a starting point and wondered if anyone has tried such a thing, or would have a direction to point me? Thanks again to Roy Harrington and Carl and the rest of you for all the great work on QTR. Between you folks and Bill Atkinson, I for one, can say you have made our printers worth many times what they were out of the box. dj
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "foggy11dj" <foggy11dj@y...> wrote:
> After great luck with QTR on an Epson 7500 with Ultrachome Inks and EEM I am now > trying to get QTR to work on my Epson 1200 with with Media Street Generations 6- > color ink set. I can't seem to find any curves out there to use as a starting point and > wondered if anyone has tried such a thing, or would have a direction to point me? > > Thanks again to Roy Harrington and Carl and the rest of you for all the great work on > QTR. Between you folks and Bill Atkinson, I for one, can say you have made our > printers worth many times what they were out of the box. > > dj
2003-11-25 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "foggy11dj" <foggy11dj@y...> wrote: > After great luck with QTR on an Epson 7500 with Ultrachome Inks and EEM I am now > trying to get QTR to work on my Epson 1200 with with Media Street Generations 6- > color ink set. I can't seem to find any curves out there to use as a starting point and > wondered if anyone has tried such a thing, or would have a direction to point me? > > Thanks again to Roy Harrington and Carl and the rest of you for all the great work on > QTR. Between you folks and Bill Atkinson, I for one, can say you have made our > printers worth many times what they were out of the box. > > dj Hi DJ, The short answer is basically that you have to design curves for what you want. But I'm not too sure what you want to do with the color inks in a 1200. QTR is for B&W (monochrome) printing so with standard G6 inks it sounds like just black-only printing. What did you do with the 7500 with UltraChrome? Do you mean a 7600? Roy
2003-11-25 by foggy11dj
Sorry for the confusion Roy, Yes it was in a 7600 with Ultrachrome inks (Matte Black) with GREAT success. Thanks so much for all your hard work on this. I have to play with the density since the curves I used are for the 2200, but other than that everything looks great. As for the 1200, I was hoping I could get it to produce similar results. I know the Genrations ink set is vastly different from the Ultrachome, but I thought someone else might have already tried this. When printing with the 7600 on QTR is is using mostly just the LK and K or does it use a combination of all 7 inks to produce a grey tone? If the answer is that QTR is set up to use mostly the LK and K inks, I can see why this wouldn't be possible with the 1200 since there is no LK. dj
> The short answer is basically that you have to design curves for what you want. > > But I'm not too sure what you want to do with the color inks in a 1200. QTR > is for B&W (monochrome) printing so with standard G6 inks it sounds like > just black-only printing. What did you do with the 7500 with UltraChrome? > Do you mean a 7600? > > Roy
You're exactly right -- with the 2200/7600 the gray scale is basically just K and LK for the basic density. There are trace amounts of LC and LM to get the color correct. With the 1200 and Gen4 you'd mainly be using just K. You could use colors just like the Epson driver to make grays but then there wouldn't be much advantage. Roy --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "foggy11dj" <foggy11dj@y...> wrote: > Sorry for the confusion Roy, Yes it was in a 7600 with Ultrachrome inks (Matte Black) > with GREAT success. Thanks so much for all your hard work on this. I have to play > with the density since the curves I used are for the 2200, but other than that > everything looks great. > > As for the 1200, I was hoping I could get it to produce similar results. I know the > Genrations ink set is vastly different from the Ultrachome, but I thought someone else > might have already tried this. When printing with the 7600 on QTR is is using mostly > just the LK and K or does it use a combination of all 7 inks to produce a grey tone? > > If the answer is that QTR is set up to use mostly the LK and K inks, I can see why this
> wouldn't be possible with the 1200 since there is no LK. > > dj > > > > > The short answer is basically that you have to design curves for what you want. > > > > But I'm not too sure what you want to do with the color inks in a 1200. QTR > > is for B&W (monochrome) printing so with standard G6 inks it sounds like > > just black-only printing. What did you do with the 7500 with UltraChrome? > > Do you mean a 7600? > > > > Roy
