Advantages of MIS UT over VM ?
2003-11-25 by lesstaken
Aside from the obvious fact that the UT inks will allow you to print on either glossy or
matte paper are there any other advantages to using the UT inks iunstead of the VM
inks ?
RE: [Digital BW] Advantages of MIS UT over VM ?
2003-11-25 by Paul Roark
>UT inks iunstead of the VM inks ?
The UT inks are more lightfast.  The VM inks are an older generation of
pigments that will warm shift and fade considerably more than the latest
generation of pigments.
Eboni also has a better dmax on a number of papers.
I also like the UT tones better.  For example, the VM "NC" curves were a bit
on the cool side to anticipate the warming of the inks.  As such, they are
actually a little colder than I like.  The UT inkset was mixed so that the
"nc" curve gives a tone that matches my lightly-selenium-toned silver
prints.
http://www.PaulRoark.com
Re: [Digital BW] Advantages of MIS UT over VM ?
Hello Paul
I found the following on the MIS website and was wondering if the Eboni referred to is
the same as the Eboni included with the UltraTone inkset ?
Early this year (2003) a new blacker pigment became available, via our pigment
supplier.  We used it to create a new black ink to replace the Double Density and VM/
FS black inks.  This new ink is a pure carbon pigment ink, like the others, but it has
fantastic fade resistance and will not shift.  After 600 hours in the Miami Sun (our test
chamber) there was no measurable change in density or and the Delta-E was zero, ie,
no shifting.  We code named this new black Eboni. It's estimated life in Wilhelm years
is well over 100.
        As of March 1, 2003,  Eboni has taken the place of the Double Density, VM & FS
black inks.  We have not changed part numbers or prices, but this is what you will
now get when you order VM, VMS, FS, FSN or Double Density Black. It has the same
Dmax, 1.72 as the other inks and will not effect profiles or workflow  curves.  It is the
best black ink we have ever  made and it is superior to Cone's Museum Black.  It is
also what we use in our PG and 7600 Archival inks as the Matte Black.  The older co-
solvent based black is no longer available.
> prints.
> Paul
Yes, it's the same Eboni black ink.
____________________________________
Sent: Tuesday, November 25, 2003 9:53 AM
Subject: Re: [Digital BW] Advantages of MIS UT over VM ?
Hello Paul
referred to is
pigment
Density and VM/
but it has
Sun (our test
zero, ie,
Wilhelm years
is well over 100.
Density, VM & FS
you will
same
curves.  It is the
It is
older co-
bit
> prints.
> Paul
page.
them short.
resources on the homepage.
