OPM/IJC together with Epson 2100
2003-11-15 by theo_kupfer
Hi, I got a used Mac, got OPM and OS9 just to recognize that it does not work with the Epson Stylus Photo 2100. Does anybody know if there is a solution to this? Best regards Theo
2003-11-15 by dave08g
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "theo_kupfer" <theo@t...> wrote: > Hi, > > I got a used Mac, got OPM and OS9 just to recognize > that it does not work with the Epson Stylus Photo 2100. > > Does anybody know if there is a solution to this? > > Best regards > > Theo Hi Theo, I have OPM, OS 9.2 and it works on my 2200. There should be no difference between 2100 and 2200 ( except input voltage). Can you describe in more detail the nature of your problem? Can you open the application? Can you select a printer? Note: Your printer must be hooked up to the computer via USB. If you are using a parallel or firewire hookup, it won't work. 2. If you can open the application and select a printer, next step is to select a profile. Two are provided with the OPM download from the Bowhaus site. Hope this helps. Dave Gordon http://www.davegordonphotography.com
2003-11-16 by theo_kupfer
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dave08g" <dave08g@y...> wrote: > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, > "theo_kupfer" <theo@t...> wrote: > > Hi, > > > > I got a used Mac, got OPM and OS9 just to recognize > > that it does not work with the Epson Stylus Photo 2100. > > > > Does anybody know if there is a solution to this? > > > > Best regards > > > > Theo > > Hi Theo, > > I have OPM, OS 9.2 and it works on my 2200. There should be > no difference between 2100 and 2200 ( except input voltage). > > Can you describe in more detail the nature of your problem? > > Can you open the application? > > Can you select a printer? > Note: Your printer must be hooked up to the computer via USB. > If you are using a parallel or firewire hookup, it won't work. > > 2. If you can open the application and select a printer, next step > is to select a profile. Two are provided with the OPM download > from the Bowhaus site. > Hi Dave, That's what I thought, that there is no difference. I could install OPM (I use OS 9.1). I can start the application and select a printer (I use USB). I can open a image and select the appropriate profiles. But when I press the print button I get the message that the printer is not supported. Hmmm Best regards Theo
