Re: [Digital BW] Digest Number 1881
2003-11-16 by Roger Smith
on 11/15/03 7:10 PM, DigitalBlackandWhiteThePrint@yahoogroups.com at
> Hi Theo,
> I have OPM, OS 9.2 and it works on my 2200.  There should be
> no difference between 2100 and 2200 ( except input voltage).
> Can you describe in more detail the nature of your problem?
> Can you open the application?
> Can you select a printer?
> Note:  Your printer must be hooked up to the computer via USB.
> If you are using a parallel or firewire hookup, it won't work.
> 2.  If you can open the application and select a printer, next step
> is to select a profile.  Two are provided with the OPM download
> from the Bowhaus site.
> Hope this helps.
> Dave Gordon
At the risk of sounding like a complete newbe - whats OPM and where can a
person find it if they wanted it?  Thanks.
Roger Smith
