Refilling 2200 carts--advice for 1st-timer?
2003-11-23 by David Wroblewski
I'm about to undertake my first refill of a Epson 2200
cart, using the MIS Ultratones. As practice, I took a spare
MIS cart and tried to fill it with water, using the
syringe they sell with the "bottom fill adapter" attached.
My understanding is that you put the tip of the
adapter into the outlet at the bottom of the cartridge and
inject the ink. Simple. But I can't inject anything--I get
infinite backpressure.
I know there is a "poppet valve" inside that seals the
cart when it is not in use; I assume the tip of the bottom
fill adapter presses that open. I get the same result no
matter how far I press the adapter into the outlet.
Obviously I'm missing some trick... can anyone offer a hint?
Or am I on Candid Camera?
All I can say is, I'm really glad I tried this with water
first!
David
Re: Refilling 2200 carts--advice for 1st-timer?
2003-11-24 by David Wroblewski
Update: Just found out I did not have the "refill friendly"
2200 carts that MIS thought I had. That was why I could not
bottom-fill them. Am going to try again when I get a set of
refill friendlies later this week.
-david
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David
> first!
> Thanks,
> David
