It's called quatization noise. There is extensive literature in the
digital signal processing, image processing, SAR processing, Tomographic
processing, etc. discussing this issue. In order to maintain a full 8
bits accuracy one must allow additional bits in the processing else the
quantization noise will impact the final signal to noise ration.
It's in the math - has nothing to do with the image. Once you have your
final image an 8 bit image is sufficient since that is probably the
limit of the eye.
Truman
Martin Wesley wrote:
> * -----Original Message-----
> * From: Tom Baker [mailto:tbaker1328@...]
> * Sent: Saturday, November 29, 2003 9:28 AM
> * To: DigitalBlackandWhiteThePrint@yahoogroups.com
> * Subject: RE: [Digital BW] 16 bit printing
> * Martin -
> * I know all of that. But, it 'feels' like something is going
> * on in the end-to-end process that seems to fly in the face of
> * the numbers/theories. In the end we may not need 16 bit
> * throughout the process to get max print quality. Or, at
> * least, not have to work in 16 bit all of the time. Maybe
> * there are improvements in the 8bit processing that the image
> * processors do.
> Tom,
> I agree. I think 8-bit is probably plenty as long as you can preserve the
> image data during adjustments. I don't think the problem can be addressed
> with better 8-bit software though. The problem is the limitation of the
> math. If you change the gamma of an image from 1 to say 2 the only way you
> can do this if all 256 shades are in use is to reassign pixels to values
> already in use and leave adjacent values empty with no pixels assigned to
> them. The number of shades of gray then is reduced from 256. I don't
> see any
> way around this.
> * If it is, in fact, true that the print engines all work in 8
> * bit, then: 1.) maybe we can drop back to 8 bit sooner in the
> * workflow without degradation, or 2.) what kind of quality
> * increase could we see if the print engines were 16 bit.
> In answer to 1.) use Photoshop CS, do all your work in 8-bit on layers and
> at the end apply the layers to the original 16-bit file. The end result
> will be a image that has negligible degradation whether you choose to save
> the end product in 8 or 16-bit mode. You can even save the layer set
> without
> the image for future revision of your adjustments.
> As far as 2.) goes I don't think you would see much if any improvement
> with
> a 16-bit printer. I suspect that our ability to differentiate shades
> of gray
> may be lower than what you can achieve in 8-bit. If you wanted to increase
> the bit depth of a print engine I think you would only need to go up
> to 10
> or 12-bit. The highest value I have ever seen published for human
> perception
> of shades of gray was in the 900 to 1025 step range and I am skeptical of
> that. So beyond 10-bit differences would definitely not be discernable to
> the human eye.
> Martin
> * Martin Wesley <mwesley250@...> wrote:
> * * -----Original Message-----
> * * From: Tom Baker [mailto:tbaker1328@...]
> * * Sent: Friday, November 28, 2003 9:46 PM
> * * To: DigitalBlackandWhiteThePrint@yahoogroups.com
> * * Subject: Re: [Digital BW] 16 bit printing
> * * Paul -
> * * What would be the result if you had started with a 16bit
> * * image, done all of your work, including the curves
> * * application, then converted to 8bit just before printing?
> * * Similarly, what happens if you apply the curve before
> * * converting to 16 bit in your most recent scenario? The
> * * reason I ask is that I'm still wondering if, when, and how it
> * * makes a difference if you print an 8 or 16bit gray file.
> * * I've printed some 8bit files that look just fine. But, that
> * * seems illogical.
> * Tom,
> * I'll put my 2 cents in here if you don't mind. For the most
> * part you can make great prints working and printing in 8-bit
> * mode. If you couldn't then we would not have gotten as far
> * with this as we have.
> * However, it is desirable to do everything in a higher bit
> * mode. As you adjust an image you can start to chop up the
> * data in 8-bit to the extent that not all of the 256 shades of
> * gray are used and your histogram appears "combed" and/or
> * fuzzy. You can actually have quite a lot of this and still
> * get a good print but you frequently wind up with problems of
> * posterization and tonal flat spots in areas like skin or
> * skies. In 16-bit with 65,536 shades of gray you can lose
> * thousands of shades and it will never be visible in the print.
> * Many people have always worked their prints from beginning to
> * end in 16-bit mode but for the majority the lack of layers
> * and other tools in 16-bit mode was not acceptable and we
> * dropped down to 8-bit after making some initial adjustments.
> * The great thing about Photoshop CS is that you now have all
> * of the tools and layers available in 16-bit that you had in
> * 8-bit. The bad news is that the working file sizes get really
> * out of hand as you start adding layers in 16-bit mode.
> * However, the good news is that you can save an initial 16-bit
> * version of your file and then an 8-bit version. Work out all
> * of your layers and adjustments in the 8-bit file. When you
> * are done put all the layers in a layer folder, open up the
> * 16-bit version of the image you saved, drag the layer folder
> * from the 8-bit to the 16-bit image and presto you have a
> * 16-bit file that is identical to what you would have had if
> * you had done all the work in 16-bit. Very cool!
> * In PS7 and earlier if you did all of your adjustments in
> * 16-bit and then converted to 8-bit before applying the RGB
> * separation curves you would "damage" the image data when the
> * curves were applied. Might or might not effect image quality
> * depending upon the image. Same thing if you applied the
> * curves to an 8-bit file prior to converting to 16-bit. Once
> * the damage has been done in 8-bit converting to 16-bit does not help.
> * If you were not using RGB separation curves, then converting
> * from 16-bit to 8-bit prior to printing would not cause you
> * any problems. However, there is no reason to convert a 16-bit
> * file to 8-bit prior to applying the curve or prior to
> * printing. Just print directly from 16-bit.
> * Martin Wesley
> * http://www.carolyn.cc/Guests/MartinWesley/pages/MW_01.html
> * http://www.borderless-photos.de/guests.html
> * Yahoo! Groups Sponsor
> * Please visit the Group Homepage to check the Files,
> * Bookmarks, Polls and other resources as they are often being
> * updated. The page is at:
> * http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> * If you wish to receive no emails or just a daily digest, or
> * you wish to unsubscribe, please edit your Membership
> * preferences by visiting this same page.
> * Please follow these basic guidelines:
> * - Include your full name with your message.
> * - Include the address of your website, if you have one.
> * - As threads develop, trim off excess portions of earlier
> * messages to keep them short.
> * - As the topic of a thread changes remember to change the
> * subject header.
> * - Good manners are required at all time. No personal attacks or flames
> * - Complete your Yahoo profile.
> * - Before posting a question, search the message archives and
> * the various resources on the homepage.
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> * [Non-text portions of this message have been removed]
> * ------------------------ Yahoo! Groups Sponsor
> * ---------------------~--> Buy Ink Cartridges or Refill Kits
> * for your HP, Epson, Canon or Lexmark Printer at MyInks.com.
> * Free s/h on orders $50 or more to the US & Canada.
> http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/ucIolB/TM
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
> other resources as they are often being updated. The page is at:
> page.
> them short.
> and other resources as they are often being updated. The page is at:
> this same page.
> keep them short.
> <http://docs.yahoo.com/info/terms/>.
