Re: Re[2]: [Digital BW] Banding on a scanner
2003-11-30 by Ernst Dinkla
From: "Daniel Staver" <daniel@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Sunday, November 30, 2003 7:25 PM Subject: RE: Re[2]: [Digital BW] Banding on a scanner > > I've recently started scanning Polaroid type 55 negs using an Epson > > 3200 with Vuescan and have not seen the banding you described. > > The example was from the 9900 that I returned, with the 3200 it's less > pronounced. Here's one I just made from the 3200: > > Converted to grayscale and increased contrast: > http://daniel.staver.no/img/3200.jpg > > Original: > http://daniel.staver.no/img/3200_2.jpg > > You'll see that the BW version has vertical banding in the sky, while > it's not easily visible in the original. > > Rotating the transparency 90 degrees on a scanner makes the problem even > less visible. > > -- > Daniel Staver > http://daniel.staver.no Several things can cause banding. The Epson uses 3 sensor strips after another that are slightly offset to one another so a higher frequency of sampling can be achieved. The sensor may not be calibrated to one another like they are not calibrated to one another on the Nikon 8000, the last suffers of banding too. Very regular and more visible in certain monotone grey fields than in other areas. Some 8000's have it more than others if the reports of users can be compared with one another. Then there's a test by C't of the Canon and Epson where the Epson scores bad on lighting evenness and the Canon not much better. I have no answer yet to what that term exactly refers too but it could be that the lamp doesn't have a constant output during the scan. To be honest my 3200 doesn't show that problem. Not related to this I think but I have observed that the planerity of the film influences the light distribution on this scanner. There's fall off to the sides when the film bulges downwards. http://members.chello.nl/e.dinkla/Verhaal.pdf Ernst
