Why so coarse grain?
2003-12-01 by akvarnsudio
Can Anyone explain.
Two days ago I thought myself to be the only one who wanted to make
nice B&W prints. One workflow I´ve tried is to convert my picture to
grayscale, adjust it and convert it into bitmap using diffusiongitter
(don´t know the english term for it) with 1000 dpi (Photoshop). The
result on screen is very similar to what I want: tiny, tiny dots of
pure black where the eye hardly can see the grain. The output from my
printer (Epson 1290) however is very coarse regardless of how the
printers resolution is set.
Is there a conflict with the printers inherent screen and would a RIP
be something that could solv this problem.
Many thanks for all answers that will help me understand.
Emilio
RE: [Digital BW] Why so coarse grain?
2003-12-01 by Paul D. DeRocco
> From: akvarnsudio [mailto:emilio.gallo@...]
> nice B&W prints. One workflow I\ufffdve tried is to convert my picture to
> (don\ufffdt know the english term for it) with 1000 dpi (Photoshop). The
But you're explicitly doing in Photoshop exactly what the Epson driver does
anyway. When you pile the Epson dithering on top of the PS dithering, you're
winding up with extra grain.
Let the driver do the dithering. Just convert your image to grayscale using
whatever tools you prefer (e.g., channel mixer, gray proof setup, Hue/Sat
adjustment layer with saturation = 0, etc.) Then, select Black Only in the
driver, and let it make the fine black dots.
The only reason one would create explicit dithering in PS is if you want the
dots larger, so you can actually see them.
Re: [Digital BW] Why so coarse grain?
2003-12-03 by akvarnsudio
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D.
DeRocco" <pderocco@i...> wrote:
> > From: akvarnsudio [mailto:emilio.gallo@t...]
make
to
diffusiongitter
The
of
from my
driver does
dithering, you're
grayscale using
Hue/Sat
in the
want the
> Paul                mailto:pderocco@i...
Thanksalot
Understand what you say, but it doesn´t work. The printers dithering
is not the same as the dithering in PS bitmap mode. I want that kind
of grain and I want to have full control over the dotgain. I want the
dots visible but just visible.
Do you know if a RIP would help?
Ciao, Emilio Gallo
2003-12-03 by Paul D. DeRocco
> Understand what you say, but it doesn\ufffdt work. The printers dithering
There really aren't many parameters to vary in dithering. You can have
different basic dot size, you can have multiple dot sizes or colors, and the
noise frequency response can vary a bit, so I'm surprised that you're
finding the printer's dithering so different from what PS does. Have you
tried reducing the printer's resolution? I forget what printer you said you
were using, but if it has a 720dpi setting, maybe you can make the dots look
more like what you want.
Whether a RIP would help, I don't know, but maybe someone else around here
does.
