Starting out with normal Epson inks?
2003-12-02 by dhappi2
I have started reading about B&W and BO printing recently and found
that is a HUGE area that I don't really have time to master right now
as I currently struggle with a million other technical issues and
digital printing is not my main business.  However I would like to
produce some "ok" quality B&W photo prints with the Epson 1280 using
the Epson inks that we currently have.  So far, everything I do looks
terrible, but am sure it is a problem with my expertise. BO is awful,
almost like the head is clogged and is out of ink, grainy beyond
belief, but there is still black ink left, and we have run the
cleaning routine repeatedly. FI is better but still has banding, the
ink still seems to spatter and crap out around any text like with BO,
and is still just really BAD quality. Printing from Photoshop 7, no
profile (at this point I don't even care about levels or tone, jsut
want it to print without banding or spatter) I Have tried grayscale,
RGB and CMYK modes, and nothing seems to help. Tried printing at 720
and 1440, 1440 is a little better but still unacceptable. I am also
wondering if this printer can handle different kinds of elements on
the page such as flat color areas/graphics, logos and text, or if
this printer is strictly for photos only?
Everything I have read says we ultimately have to buy the Eboni inks
for BO and/or others for FI, but I want to get at least a passable
quality from the standard inks with this printer or I don't think I
am going to have much luck with better inks. I have a need to print
just 2 photos in the next two days of passable quality and don't have
a lot of time to learn or order special/expensive inks.  Later I
would like to learn and get better inks, but right now we just need
to get something done. I had assumed that this printer was capable of
basic printing with the standard inks, perhaps I am on the wrong
track and my problem is somwhere in a software setting or I have a
bad cartridge?
Is there a way to get the best possible quality out of the
1280/Photoshop 7 with the Epson inks?
Windows Xp
Photoshop 7
Epson 1280 Photo
Thank you in advance for any help you can offer.
Re: Starting out with normal Epson inks?
2003-12-02 by bwinkjet
You can print black only and achieve good prints using Epson OEM
inks for the 1280.  The problem with longevity remains with dye
inks.  This link to Clayton Jones articles will get you started in
no time.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dhappi2"
found
now
using
looks
awful,
BO,
no
jsut
grayscale,
720
also
on
inks
I
print
have
need
of
> bad cartridge?
> Windows Xp
> Photoshop 7
> Epson 1280 Photo
Sorry, the link was http://www.cjcom.net/digiprnarts.htm for the
black only instructions.
found
now
using
looks
awful,
BO,
no
jsut
grayscale,
720
also
on
inks
I
print
have
need
of
> bad cartridge?
> Windows Xp
> Photoshop 7
> Epson 1280 Photo
Thanks so much,
I did read these articles, and I think he was using the specialty
inks and a 2200 (I have a 1280.)  Do these steps still apply?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwinkjet"
> Paul
Yes he was.  But the same instructions work well with a 1280 and
Epson dye inks.  I have a number of prints made this way and other
than longevity issues they are great.  If your printers nozzles are
clear and you get good patterns on checks, BO using Clayton's
suggested settings will be a very good place to start before you
tweak the image to achieve your personal vision.  Hope it works for
you.
> Thanks so much,
> > Paul
Re: [Digital BW] Starting out with normal Epson inks?
2003-12-03 by Alan Zinn
>bad cartridge?
>Windows Xp
>Photoshop 7
>Epson 1280 Photo
You shouldn't be having so many problems getting a very good B/O print. If
it looks good on the screen it should also print well.  I use the 1280 with
plain Epson or MIS dye inks. My images from 35mm panorama negs are around 4
to 6 in. high by whatever length at 360-700 DPI, scanned with a Epson 3200
scanner at 3200 DPI.  I print the grey scale image 1440 on EAM.  with no
other adjusting. Behind glass they are easily mistaken for silver prints.
You have looked at this haven't you?: http://www.cjcom.net/digiprnarts.htm
AZ
Build a Lookaround!
The Lookaround Book, 2nd ed.
NOW SHIPPING
http://www.panoramacamera.us
